Guest #1 Posted January 26, 2016 (edited) Edited January 26, 2016 by BT Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,512 #2 Posted January 26, 2016 Last model for the long frame tractors to use the 4 chute rollers 1980 model 06-42ST01 First model for the long frame tractors to use skids 1983 model 06-42ST03 or so I thought. Yours is different. Maybe those are not rollers and you have the plastic collar inside the chute. Last model for the long frame tractors to use the short chute with plastic collar 1990 model 06-42ST06 No model and serial number here? Share this post Link to post Share on other sites
Guest #3 Posted January 26, 2016 (edited) Thank you for the information.The model and serial # are completely worn off the label.It does have a plastic collar in the chute and has skids.So from your info it would appear that it is somewhere between 83' and 90'.I'm also wondering what Toro/Wheelhorse tractors this will work on?I have the shorter flag connecting rod that came with it.Can this snow blower only be used on long frame tractors? Edited January 27, 2016 by BT Share this post Link to post Share on other sites
