tsmall07 49 #1 Posted January 26, 2016 (edited) Anyone know what it is? 520-H Edited January 26, 2016 by tsmall07 Share this post Link to post Share on other sites
Aldon 4,832 #2 Posted January 26, 2016 Looks like retaining pin for PTO. At least from my tractor. I have never had a 520. 5 Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted January 26, 2016 I agree with Aldon 2 Share this post Link to post Share on other sites
Ed Kennell 45,709 #4 Posted January 26, 2016 That's what I have on my 520 PTO. 2 Share this post Link to post Share on other sites
tsmall07 49 #5 Posted January 26, 2016 Duh... I remember now. Thanks! 1 Share this post Link to post Share on other sites
Ed Kennell 45,709 #6 Posted January 26, 2016 If you're lucky, you'll also find the " U " bracket nearby. 1 Share this post Link to post Share on other sites
tsmall07 49 #7 Posted January 26, 2016 That actually doesn't look like what it is. My pto looks all together. This clip is much larger than tree one on the pto, unless I'm confused. Share this post Link to post Share on other sites
Ed Kennell 45,709 #8 Posted January 26, 2016 Has someone else been in the 520s stall? 1 Share this post Link to post Share on other sites
tsmall07 49 #9 Posted January 26, 2016 Negative. I'm not even completely positive it goes to the WH. It's not in its normal spot. It looks like a WH part, though. Share this post Link to post Share on other sites
857 horse 2,588 #10 Posted January 26, 2016 2 minutes ago, ekennell said: Has someone else been in the 520s stall? Ed,,,,,,im just hopin the guy with the low hours 520 that wont push,,,,,will be patient with it......find the fix....and let it live a full life... TS,,,,,,your the closest neighbor yet.......Howard in Stafford VA.....Good to meet you...rains coming....maybe !! lolo 3 minutes ago, tsmall07 said: Negative. I'm not even completely positive it goes to the WH. It's not in its normal spot. It looks like a WH part, though. 45 minutes ago, tsmall07 said: That actually doesn't look like what it is. My pto looks all together. This clip is much larger than tree one on the pto, unless I'm confused. Share this post Link to post Share on other sites
Callen 64 #11 Posted January 26, 2016 Could be a hitch pin 1 Share this post Link to post Share on other sites
Ed Kennell 45,709 #12 Posted January 26, 2016 Axle bracket lever lock ? Share this post Link to post Share on other sites
WNYPCRepair 1,924 #13 Posted January 26, 2016 The PTO pin is the only thing on my 520 that looks anything like that. Those pins are used in a lot of equipment though, could be from anything. Maybe it was on the flor and someone kicked it under without noticing? Share this post Link to post Share on other sites
tsmall07 49 #14 Posted January 26, 2016 15 minutes ago, 857 horse said: TS,,,,,,your the closest neighbor yet.......Howard in Stafford VA.....Good to meet you...rains coming....maybe !! lolo I met another guy in Springfield. I sold him a snow blower last year. We should meet up sometime. 9 minutes ago, ekennell said: Axle bracket lever lock ? You mean for the snow blow levers? Mine just have bolts. 11 minutes ago, Callen said: Could be a hitch pin A little big for a hitch pin, I think. Share this post Link to post Share on other sites
Ed Kennell 45,709 #15 Posted January 26, 2016 3 minutes ago, tsmall07 said: You mean for the snow blow levers? No, rear axle bracket for mounting snow plow. The levers are locked closed with a pin or bolt. Share this post Link to post Share on other sites
tsmall07 49 #16 Posted January 26, 2016 1 minute ago, ekennell said: No, rear axle bracket for mounting snow plow. The levers are locked closed with a pin or bolt. We're talking about the same thing. I meant to write snow PLOW levers. Mine are secured with bolts. 1 Share this post Link to post Share on other sites
