Pollack Pete 2,273 #1 Posted January 25, 2016 I picked up a non-running C-195 a few weeks ago.This week end I pushed it in the shop and I'm going to bring it back to life.Of course,this has a Kohler KT19 twin engine.I took all the engine tins off to de-crud the cylinder and head fins.Noticed on the rear cylinder,on the flywheel side of the engine,a small nipple sticking out.Looks like for maybe a 1/8 inch vacuum hose?? No vacuum gauge on this tractor.Anyone know what it's for? Should I plug it off while the flywheel cover is off for cleaning?Inquiring minds want to know. Share this post Link to post Share on other sites
953 nut 64,221 #2 Posted January 25, 2016 Here is the manual for your engine, I don't have one of these but I would say a vacuum outlet should have a hose or a cap on it. Share this post Link to post Share on other sites
bobert94 38 #3 Posted January 25, 2016 No its not for a vacuum hose. its a roll pin used to set the ignition timing with a timing light there is also marks on the flywheel 2 Share this post Link to post Share on other sites
baerpath 517 #4 Posted January 25, 2016 45 minutes ago, bobert94 said: No its not for a vacuum hose. its a roll pin used to set the ignition timing with a timing light there is also marks on the flywheel Yup he's right 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #5 Posted January 26, 2016 Thanks guys.I feel like a dummy.Sure looked like a hose nipple.........How do you time these engines??? Share this post Link to post Share on other sites
bobert94 38 #6 Posted January 26, 2016 There is a access hole in the fan shroud pull out the snap in plug,hook up timing light shine through hole and line up flywheel marks with the roll pin. check the service manual for complete instructions 1 Share this post Link to post Share on other sites
