grine_22 145 #1 Posted January 18, 2016 I know I have ran across it before, but I have 12 HP Kohler with gen/start on it, I know I need a keyswitch w B, I, S on it, can anyone tell me a toro pn and is this a keyswitch that is grounded or no? Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted January 18, 2016 What is the model number of your tractor? Does the switch have 3 keys positions or 4 positions? Early 1968 production model 1-6231 If you have points ignition using a tall round ignition coil with a condenser connected to the (-) coil terminal you have battery ignition and no ignition switch ground is required. Ignition terminal on the switch identified with an I (eye). Uses 7263 (Threads 9/16"-24) 3-terminal 3-position BAT-IGN-ST ignition switch Late 1968 production model 1-6231 If you have points and a magneto under the flywheel this is magneto ignition and a ground is required on the ignition switch. Ignition terminal on the switch is identified with an M If you have breakerless ignition with an odd shaped ignition coil this is also treated like magneto ignition and a ground is required on the ignition switch. Ignition terminal on the switch is identified with an M Uses (~7572 3-terminal 3-position B-M-S) replaced by 101482 3-terminal 3-position B-M-S ignition switch Garry 1 Share this post Link to post Share on other sites
grine_22 145 #3 Posted January 18, 2016 Thank you I appreciate the help. I have an early production 68. Picked up a switch that will work for me. Share this post Link to post Share on other sites
