Black64galaxie 65 #1 Posted January 18, 2016 Another question on my 520. The parking brake will not work. I took the panel off the tunnel area and looked into the lever. Is there supposed to be some kind of hook or something to keep the lever down. I'm thinking something broke and is missing. Any photos pf what it is supposed to look like ? Share this post Link to post Share on other sites
HokieAg07 129 #2 Posted January 18, 2016 (edited) The teeth on the black piece (lower center of picture) will catch on the parking brake lever that you engage. Brake system is very simple on these tractors. I suggest you look up a parts breakout, available on this site in the manual section, to get a better idea of how it all goes together. Edited January 18, 2016 by HokieAg07 1 Share this post Link to post Share on other sites
JAinVA 4,638 #3 Posted January 18, 2016 I had the same issue with the last two I brought home.In both cases the adjustment of the brake band was so tight that I could not out enough pressure on the brake pedal to get the teeth to engage.You might loosen the adjustment nut some and see if that helps.Luck.JAinVA 1 Share this post Link to post Share on other sites
Black64galaxie 65 #4 Posted January 18, 2016 Yes it looks like I have the black rectangular lever that goes up and down . I see the tooth bracket just can't see what interacts with the tooth mechanism. I'll look into the brake band adjustment also. Thanks. Share this post Link to post Share on other sites
cleat 9,324 #5 Posted January 18, 2016 9 hours ago, HokieAg07 said: The teeth on the black piece (lower center of picture) will catch on the parking brake lever that you engage. Brake system is very simple on these tractors. I suggest you look up a parts breakout, available on this site in the manual section, to get a better idea of how it all goes together. Holy crap, is that ever a clean machine ! 1 Share this post Link to post Share on other sites
WHX?? 58,053 #6 Posted January 18, 2016 I was thinkin the same thing Cleat, for a 1990??? Maybe never saw a deck??? I'm also thinking we might need to see more pictures on this gal?? This might be one I was eyeballing on CL a while back??? BTW galaxie Share this post Link to post Share on other sites
HokieAg07 129 #7 Posted January 19, 2016 13 hours ago, cleat said: Holy crap, is that ever a clean machine ! 10 hours ago, WHX6 said: I was thinkin the same thing Cleat, for a 1990??? Maybe never saw a deck??? I'm also thinking we might need to see more pictures on this gal?? This might be one I was eyeballing on CL a while back??? BTW galaxie Oh no fellas, the picture is of a 97 314H I had a while back. Sold it to another RedSquare lurker. It was the cleanest machine I had ever seen. My 416 is a worker and looks nothing like this. My 520 is close but not quite. 1 Share this post Link to post Share on other sites
WHX?? 58,053 #8 Posted January 19, 2016 That explains it ....thought we had a almost a new on shelf here!! Share this post Link to post Share on other sites
arrkerr 54 #9 Posted January 21, 2016 On 1/18/2016 at 9:46 PM, Black64galaxie said: Another question on my 520. The parking brake will not work. I took the panel off the tunnel area and looked into the lever. Is there supposed to be some kind of hook or something to keep the lever down. I'm thinking something broke and is missing. Any photos pf what it is supposed to look like ? If you haven't gotten it figured out, let me know and I could easily take a video of mine working if the photos didn't quite explain it. 1 Share this post Link to post Share on other sites
Nelson webster 0 #10 Posted January 7, 2019 I can not see what the teeth will catch on either, would some one have a picture with the black piece out of the machine ,maybe mine is missing something ? Thanks Share this post Link to post Share on other sites
