Shynon 7,728 #1 Posted January 17, 2016 Did some searching and could not find my answer so I will ask. What switch is used for HL 5 headlights and where does it mount on a wedge hood? I have a set on my 1045 I need to wire up and I want to make sure I have the correct switch and mounting location. Pictures please if you have what I am looking for. Thanks Tom Share this post Link to post Share on other sites
AMC RULES 37,260 #2 Posted January 17, 2016 (edited) Switch equilivent is a Cole Hersee #5007 Edited January 17, 2016 by AMC RULES Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #3 Posted January 17, 2016 Have you seen the instructions? Garry Share this post Link to post Share on other sites
Shynon 7,728 #4 Posted January 17, 2016 13 minutes ago, gwest_ca said: Have you seen the instructions? Yes I have them, I was not sure if the switch mounted differently on a wedge hood. Now I see two holes on the side of the hood stand that would be used to mount the switch. Now I need to find the mounting bracket or make one. Thanks Tom Share this post Link to post Share on other sites
RedRanger 1,470 #5 Posted January 18, 2016 To further this discussion.... In what year/model did WH change the switch bracket? The earlier bracket is a simple "Z" bracket carried over from the 1961-1962 HL-22 and the later kit has a newer more complicated better looking stamped bracket for the HL-5. The manuals for each kit reflect the HL-22 "Z" bracket in the drawings for both the HL-22 and the HL-5. So the early HL-5 kit still used the earlier HL-22 switch bracket. Was there a specific year or model the simple Z bracket went away? I've seen 63 and 64 models with the simple Z bracket. 2 Share this post Link to post Share on other sites
