6.0 powerstroke 62 #1 Posted January 17, 2016 My plow machine hasn't seen much (any) use this winter, so I figured while it was warm and I had time I would make sure it would start and run still nope, won't start, check spark, fuel filter is full, fires off ether, and fuel starts dumping out of the carb. I pull the carb off and find a jelly/goo inside the fuel bowl and all up in the jet apparently I put regular gas in over the summer at some point , instead of ethanol free. At least I caught it before I needed it 1 Share this post Link to post Share on other sites
Howie 899 #2 Posted January 17, 2016 I have seen that several times from that ethanol laced gas. Sometimes it seems like it does not have to sit very long either. I showed some I drained out of a mini tiller to the owner who is a farmer, he couldn't believe it until seen. He buys his fuel from the Farm Bureau Co-op because he thinks it sells his grain. David Share this post Link to post Share on other sites
6.0 powerstroke 62 #3 Posted January 17, 2016 This tractor sat quite a bit this year, so I wonder if some moisture got into the fuel too ive seen gunk and crud before , but not this stuff Share this post Link to post Share on other sites
ACman 7,655 #4 Posted January 17, 2016 I've been using Star Tron fuel additive with all gas and seems to be working so far. 1 Share this post Link to post Share on other sites
Howie 899 #5 Posted January 17, 2016 I think the moisture is what will cause this. The first time I encountered what you have I had cleaned a carb and a few weeks later it was back with the same thing. Dhould have drained all the fuel in the thing I guess. This was on one of those green tractors. Share this post Link to post Share on other sites
roadapples 6,983 #6 Posted January 17, 2016 24 minutes ago, ACman said: I've been using Star Tron fuel additive with all gas and seems to be working so far. Same here. Been using it for about five years. So far so good.. 1 Share this post Link to post Share on other sites
varosd 1,185 #7 Posted January 17, 2016 only running ethanol free in all my small engines. a bit more money but after you add up the cost of those additives it evens out. a great web site to find a ethanol free gas station near you. http://pure-gas.org/ 4 Share this post Link to post Share on other sites
Tankman 3,523 #8 Posted January 17, 2016 I like Berrymans products. Work great, https://www.berrymanproducts.com/ My grandson and I drive to our local airport. Gas is 100 octane, low lead, non-ethanol. 2 Share this post Link to post Share on other sites
Shynon 7,479 #9 Posted January 17, 2016 My local gas station has 92 octane, no ethanol for the HD guys and muscle cars. I use that, sure it cost a little more but I only buy 2.5 gallons at time, never any problems like that. Clean her up and switch to non ethanol fuel and you should be good. 3 Share this post Link to post Share on other sites
Wishin4a416 2,191 #10 Posted January 17, 2016 Some ugly stuff. I see that every spring at fishing camp at Erie. Carbs are rebuilt because boat isnt running right. Sometimes it is reddish in color because of the Winter additive. A mobile mechanic service gets a lot of work out of my camp because of that ethanol.I always fogged my motors and ran them dry and never had any issues. Share this post Link to post Share on other sites
KC9KAS 4,744 #11 Posted January 17, 2016 That is why I add a can of SEAFOAM to every 5 gallon can of gasoline I buy! Share this post Link to post Share on other sites
DennisThornton 4,771 #12 Posted January 17, 2016 Startron, Stabil, Seafoam or something. I've just had too many troubles with 10% Ethanol gas! It's OK to use but not to sit or store. I used to add something to ALL gas that came home in a can but now I don't for the machines I use all the time. After a year I have no complaints. I don't use untreated in 2 cycles though! Even though most 2 cycle oil has stabilizer I've still had problems. I'm tired of tearing apart those little carbs! Share this post Link to post Share on other sites
clueless 3,225 #13 Posted January 17, 2016 For the past 20 years I store 45gal. of gas during hurricane season, I used to use stabil, or startron. About 10 years ago found this stuff PRI-G, works better the the other, gas has a longer shelf, and cheaper,16oz bottle treats 250 gal of gas. Hard to find locally, $24.00 on Amazon. A few years ago I had a 15gal container of gas with this stuff in it that was 2 years old, used it with no problems. I do use non-ethanol gas so this my be over kill but it's cheap insurance, hate it when my equipment or outboards won't run when I need them! Chris in f Florida 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #14 Posted January 17, 2016 2 hours ago, clueless said: For the past 20 years I store 45gal. of gas during hurricane season, I used to use stabil, or startron. About 10 years ago found this stuff PRI-G, works better the the other, gas has a longer shelf, and cheaper,16oz bottle treats 250 gal of gas. Hard to find locally, $24.00 on Amazon. A few years ago I had a 15gal container of gas with this stuff in it that was 2 years old, used it with no problems. I do use non-ethanol gas so this my be over kill but it's cheap insurance, hate it when my equipment or outboards won't run when I need them! Chris in f Florida I had almost forgotten that I bought a bottle of PRI-G intended for the same purpose. Haven't tried it but it sounds like you have proven it! Good to hear and thanks for sharing! For long storage I would definitely suggest non-ethanol! Share this post Link to post Share on other sites
Digger 66 3,488 #15 Posted January 17, 2016 (edited) http://www.tractorsupply.com/tsc/product/mechanic-in-a-bottle-4-oz?cm_mmc%3DSEM-_-Google-_-DynamicAdGroups-_-AllSiteTSCCirc1601&gclid=Cj0KEQiAlO20BRCcieCSncPlqqMBEiQAOZGMnJzQZk2F7I87gFkun9YhYeZe_se5zS4WE6TgRPUo_OIaAgDt8P8HAQ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Is the only stuff I've see on YouTube that will actually "bond" water molecules to fuel so it can be burnt . Edited January 17, 2016 by Digger 66 1 Share this post Link to post Share on other sites
lynnmor 7,789 #16 Posted January 18, 2016 While additives might be some help, just remember that when you buy 10 gallons you get 1 gallon of ethanol to deal with. A few tablespoons of anything can't be expected to do very much. Share this post Link to post Share on other sites
Martin 2,133 #17 Posted January 18, 2016 3 minutes ago, lynnmor said: While additives might be some help, just remember that when you buy 10 gallons you get 1 gallon of ethanol to deal with. A few tablespoons of anything can't be expected to do very much. Yep, thats why I don't bother with additives and ethanol gas. I only buy Premium ethanol free gas from the same station for all my equipment. That goes for all my vehicles too. Everything just runs better and i never have to deal with any of the ethanol related issues i see in this thread or on the forum. The only time i deal with these issues is when i pick up a new to me piece of equipment and the previous owner has let it sit with that crap in the gas. 1 Share this post Link to post Share on other sites
