Gernzz8 38 #1 Posted January 13, 2016 I am entertaining purchasing a: Brinly BS-38BH Sleeve Hitch Tow Behind Box Scraper, 38-Inch. Will my Kohler 10Hp and 8 Speed Trans be able to handle it? Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted January 13, 2016 it will handle it no problem you may need more traction 2 Share this post Link to post Share on other sites
Gernzz8 38 #3 Posted January 13, 2016 I was going to add wheel weights 55Lb rear & 30Lb front. I have Turf Saver tires on it currently. I'm guessing I will probably have to use AG tires? Share this post Link to post Share on other sites
AMC RULES 37,259 #4 Posted January 13, 2016 Filled turfs, with the weights should do the trick. 1 Share this post Link to post Share on other sites
Gernzz8 38 #5 Posted January 13, 2016 "Filled" meaning Washer Fluid or Weights? 1 Share this post Link to post Share on other sites
Gernzz8 38 #6 Posted January 13, 2016 Both I presume. Thanks AMC 2 Share this post Link to post Share on other sites
Don1977 606 #7 Posted January 14, 2016 Weights will help, but you will able to pull the Brinkly box scraper with out them. Share this post Link to post Share on other sites
wrightorchid 261 #8 Posted January 14, 2016 If you need to move a lot of dirt, or hard packed, be sure to till the area first, to roughly the depth you need. This will make it possible to move, when not using a bull dozer. Share this post Link to post Share on other sites
Gernzz8 38 #9 Posted January 14, 2016 My soil isn't that hard/compacted, I start hitting sandy soil at 3 1/2 to 4 feet. I'm thinking wheel weights front and back as well as a concrete block on the scraper. Attempt it when the soil is moist. What's the skinny on filling your tires with Washer Fluid?.......What about a tire repair with the fluid in it? Share this post Link to post Share on other sites
Racinbob 13,045 #10 Posted January 14, 2016 Click on the 'Filling Tires' below and it will take you to a good thread on the subject Share this post Link to post Share on other sites
Gernzz8 38 #11 Posted January 23, 2016 Would Carlisle Big Bites Trupower AT Tires (523367) - 23x10.50-12....Fit on my B100, original tire size is 23X8.50-12 Would they be alright to use for lawn mowing as well or will they leave a trail. Share this post Link to post Share on other sites
