Gernzz8 38 #1 Posted January 11, 2016 My Amp meter bounces like crazy pretty much all the time. Almost evenly POS. to NEG? I haven't delved into the connectors and of the like yet. Just putting it out there before I start. Any Ideas. All the Best, Danny Share this post Link to post Share on other sites
doc724 925 #2 Posted January 11, 2016 I seem to recall (like back when I was in high school) that an ammeter is simply a voltmeter with an internal shunt. If it is bouncing around from positive to negative, it may be receiving unrectified voltage. Just a guess. Other RS members will jump in here as I am sure you are not the first one to have this problem. Share this post Link to post Share on other sites
Cleaverkid 11 #3 Posted January 11, 2016 I've got an 864 with the original starter/generator and voltage regulator on top. My meter does the same thing. I've discovered that if I put my hand firmly on the voltage regulator and push down hard the bouncing stops and the meter acts normal. So I'm guessing I've got some sort of grounding issue, but so far I haven't figured out what needs to be grounded to what. Tried just running a solid wire from the base of the v.r. to ground, but that didn't do it, so I'm wondering if there's something internal on the v.r. that's not making good ground. Maybe that's someplace for you to start. Joe Share this post Link to post Share on other sites
RedRanger 1,469 #4 Posted January 11, 2016 (edited) I've never had an amp meter that stayed steady when running. They've all bounced. I assumed that's why everyone evolved to volt meters. Never had an issue with volt meters. To me, an amp meter does nothing more than tell you something is happening. If it's pegged one way or the other, then you have an issue. Edited January 11, 2016 by RedRanger Share this post Link to post Share on other sites
whtractors24 3,361 #5 Posted January 11, 2016 I just put a Brand new amp meter in my 753 it bounces very little ! 1 Share this post Link to post Share on other sites
Gernzz8 38 #6 Posted January 11, 2016 If you dig deep enough on this site you can find pretty much anything you need. I found a thread from Feb. 9, 2013 "Voltmeter Problem", rmaynard posted an Awesome wiring diagram to convert an Amp Gauge to a Voltmeter. I like the idea of seeing my voltage "Live". However, I'm not sure I want to change from "Original"? The interesting part is that at times (very few) the Amp Gauge will lean toward Pos. and have minimal movement. Danny 3 Share this post Link to post Share on other sites
russellmc301 600 #7 Posted January 11, 2016 i just know my horse has one i don't even look at but once or so if something is not working. 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #8 Posted January 11, 2016 39 minutes ago, Gernzz8 said: If you dig deep enough on this site you can find pretty much anything you need. I found a thread from Feb. 9, 2013 "Voltmeter Problem", rmaynard posted an Awesome wiring diagram to convert an Amp Gauge to a Voltmeter. I like the idea of seeing my voltage "Live". However, I'm not sure I want to change from "Original"? The interesting part is that at times (very few) the Amp Gauge will lean toward Pos. and have minimal movement. Danny Do you have the link for this. I searched to no avail. Interesting read I would think. Share this post Link to post Share on other sites
Gernzz8 38 #9 Posted January 11, 2016 Here you go Jack: 1 Share this post Link to post Share on other sites
953 nut 59,879 #10 Posted January 12, 2016 My guess would be that a wire terminal at the regulator or Amp Meter is about to come apart and is only making momentary contact. Give them all a good cleaning and make sure the regulator is well grounded, see if that helps. 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #11 Posted January 12, 2016 1 hour ago, Gernzz8 said: Here you go Jack: Thank You. And I would have to agree with Richard. Odd things happen if the regulator is not grounded good. Share this post Link to post Share on other sites
