jim1980cj5 1 #1 Posted January 5, 2016 I have a late 70s c165 wheel horse it idles fine but when i throttle it up runs like crap Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,711 #2 Posted January 5, 2016 Single cylinder Kohler or B&S twin cylinder? Garry Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted January 6, 2016 @jim1980cj5 to Share this post Link to post Share on other sites
953 nut 62,071 #4 Posted January 6, 2016 Could be caused by a few things. It could be as simple as a plugged fuel filter or loose carb. mounting bolts or bad spark plugs. Have you cleaned and rebuilt the carburetor? Some gains can be made on dirty fuel systems by adding some "SeaFoam Gas Treatment and spraying SeaFoam Carburetor Cleaner into the air inlet while the engine is running at mid throttle. Another consideration might be to readjust the high speed needle on the carb. Let us know what you have tried and what the results were. Share this post Link to post Share on other sites
jim1980cj5 1 #5 Posted January 6, 2016 Single cylinder kohler Did with both new and old carb New points condenser and coil Share this post Link to post Share on other sites
953 nut 62,071 #6 Posted January 6, 2016 If you have a good strong spark and know that you have good fuel flow to the carb. then you may want to remove the head and remove any carbon accumulation and make sure there isn't some carbon preventing the valves from closing completely. Hope this helps. Share this post Link to post Share on other sites
Ed Kennell 43,046 #7 Posted January 6, 2016 11 hours ago, 953 nut said: If you have a good strong spark and know that you have good fuel flow to the carb. then you may want to remove the head and remove any carbon accumulation and make sure there isn't some carbon preventing the valves from closing completely. Hope this helps. Dick is right on. Make sure you have good spark at the plug. I know you tried a new carb, but are you sure you have a good fuel supply to the carb? Pull the line off at the carb and see if you have a strong supply when you crank the engine. Make sure you pump into a container. If it runs better when you squirt fuel directly into the carb, it indicates you still have a fuel delivery problem. Possibilities are clogged tank cap vent hole, clogged screen in tank, dirty fuel filter, soft restricted fuel lines, bad fuel pump, air leaking in at carb mounting flange or around throttle shaft. I agree with Dick, You must have good spark and a good fuel supply. If so, then look for a compression problem ie valves not functioning properly. I would Check clearances first then pull the head and check seating. 2 Share this post Link to post Share on other sites
shadyady 24 #8 Posted January 7, 2016 I had same problem changed my carb points coil plug turns out to be faulty condenser easily overlooked mine runs spot on now was a swine to find. 1 Share this post Link to post Share on other sites
jim1980cj5 1 #9 Posted January 8, 2016 Thanks for the help going to start eliminating the possible problems this weekend 1 Share this post Link to post Share on other sites
