KC9KAS 4,746 #1 Posted January 2, 2016 Got a call from a fellow that picked up one of my cards at a show last fall. The guy wanted me to work on his 312-8. One of the things he didn't like was a previous owner put a long bolt on the left side so the lift handle would only go down so far. I have all the side panels off and I do not see any type of "height adjustment" other than the back wheels on a mowing deck. I looked into the manuals an think it should have an adjuster. Anyone shed any light on this for me? Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted January 3, 2016 If you can find a height adjuster from a parts tractor it will bolt right on. You will need to cut the half circle holes in the 2 panels where the shaft comes thru. I had to do this on a Work Horse. 1 Share this post Link to post Share on other sites
Wishin4a416 2,594 #3 Posted January 3, 2016 I have an 87 and it has no adjuster. I never did understand that. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted January 3, 2016 (edited) the cheaper tractors didn't have the adjuster,like my 308,bare bones and I guess the height adjuster was for the higher end models,as stated easy to add Edited January 3, 2016 by can whlvr Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #5 Posted January 3, 2016 My 87 310-8 did not have an adjuster , so I bought the parts and installed it . Did not have any problems. I wonder if it had something to do with WH doing away with the solid lift rod and going to the chain lift. Share this post Link to post Share on other sites
can whlvr 994 #6 Posted January 3, 2016 I don't think that's it because my 1986 308 didn't have it and my 1989 414 does,so does my 87 414,the 400 series were a higher end machine Share this post Link to post Share on other sites
Tankman 3,528 #7 Posted January 5, 2016 On 1/3/2016 at 7:17 PM, N3PUY said: If you can find a height adjuster from a parts tractor it will bolt right on. You will need to cut the half circle holes in the 2 panels where the shaft comes thru. I had to do this on a Work Horse. I did the same on a 16 hp Work Horse. Easy enough. $10 0n eBay. Be sure to get all the parts. Share this post Link to post Share on other sites
sorekiwi 761 #8 Posted January 6, 2016 One other note - the height adjuster shouldnt be used to set mower deck height, that should be set with the adjusters on the deck wheels. But for plowing snow or a mid mount grader blade, I think the dial-a-height is essential. Share this post Link to post Share on other sites
dcrage 634 #9 Posted January 6, 2016 43 minutes ago, sorekiwi said: "the height adjuster shouldnt be used to set mower deck height" I know this is the 'official line' for mower decks on WHs, BUT I have gotten tons of use from my 310-8 with a 37" SD deck cutting heavy, heavy yard material using the dial-a-height to speed up the cutting process -- Just the extra inch or two that the deck is raised helps immensely with the grass load coming out of the mower and I can't tell any problems with cut quality (But then how can be commenting on cut quality when you are mowing 3 ft tall fescue/blue grass/clover?) 1 Share this post Link to post Share on other sites
