erickson13455 1 #1 Posted December 27, 2015 I have a 78 d160 with onan. I cant get the float and needle to adjust correctly. The engine keeps running out of gas. I did work fine until just now. I tried to adjust the float so that it was flat to top of carb, so that it would take more fuel in bowl to seat the needle, No luck still runs out of gas. If I take the needle out it will spit gas out the top of carb while running. Do I need a new float or needle? I have the "foam" type float. Is the float getting stuck up? Any ideas, Thanks! Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted December 27, 2015 Is your fuel pump working good. Maybe its not getting the proper gas flow. Also check the tank filter.--Wayne Share this post Link to post Share on other sites
erickson13455 1 #3 Posted December 27, 2015 Yes the pump is working. I pumped it into a can while cranking the engine. Put a new filter on it also. Is it possible to bend the tang on float to adjust it? Share this post Link to post Share on other sites
the_nite_owl 15 #4 Posted December 27, 2015 The old foam floats will swell from being exposed to ethanol in the fuel. The swelling causes them to get stuck against the inside of the carb body. I had the same issue on my D160 and replaced it with a metal float I found on eBay. Share this post Link to post Share on other sites
erickson13455 1 #5 Posted December 27, 2015 Did you replace just the float. Do you use the same needle? Thanks, Share this post Link to post Share on other sites
the_nite_owl 15 #6 Posted December 27, 2015 I did a normal rebuild which does not include the float and the problem still existed so I replaced the float. They do not have to be changed together though. Share this post Link to post Share on other sites
erickson13455 1 #7 Posted January 1, 2016 Got the brass float installed. It "runs" now, gets gas, but it runs rough, and backfires a lot. What do I need to do now? I tried adjusting the jets, started at 2 turns out. Can't seem to get this right. Do you have to adjust the new float. I need help. Thanks, Share this post Link to post Share on other sites
JackC 617 #8 Posted January 1, 2016 (edited) If it is backfiring it may be too lean. Do you have the service manual? Initial Adjustment: 1. Turn main fuel valve clockwise until it just closes. Do not open main fuel jet more than 1/2 turn beyond the maximum power point as this could cause spark plug foulingetc. 2. Now open main fuel valve 2 turns counterclockwise. 3. Close idle valve in same manner and open it one turn (counterclockwise). 4. This initial adjustment will permit engine to start and warm up prior to final adjustment. Final Adjustment: 1. Turn main fuel valve in until engine misses (lean mixture), then, turn it out past the point where engine runs smoothly until engine runs unevenly (rich mixture). Turn valve to mid-point between lean and rich so engine runs smoothly. 2. Hold engine at idle position and set low speed adjustment screw (Figure 8) until a fast idle is obtained (1200 rpm). 3. Hold throttle in idle position and turn idle adjustment valve in (lean) and out (rich) until engine idles smoothly. 4. Reset low speed adjustment screw so engine idles at 1200 rpm. 5. Release throttle - engine should accelerate without hesitation. If engine does not accelerate properly, readjust main fuel valve by turning out slightly. Important: Do not open more than 1/2 turn beyond maximum power point. Edited January 1, 2016 by JackC Share this post Link to post Share on other sites
erickson13455 1 #9 Posted January 1, 2016 Do you adjust the valves with the air filter and blower on, or off. I got it to idle pretty decent. When I try to throttle up it runs rough and will not run at max RPM. How do I know if it is rich or lean. On the main screw I went from 1 turn out to 5 turns out. It will not stay running at full throttle? It seemed to be able to run at about half throttle with the air filter and blower on it, but not at full throttle. If there is a tad bit of white smoke in exhaust is it lean or rich? I have never replaced the gasket in the carb. It is in good shape, but will that cause problems. Thanks, Share this post Link to post Share on other sites
erickson13455 1 #10 Posted January 2, 2016 I have never checked the points, I think I will check those. Will bad points cause it to miss at full throttle, but run at idle just fine? Share this post Link to post Share on other sites
erickson13455 1 #11 Posted January 10, 2016 I checked the points and they look shiny clean. I measured about a .018 gap at open. I put on new spark plugs. Will not stay running at full throttle and backfires. Is backfiring to rich or too lean? I measured the coil. ~3.8 ohms, ~15,800 ohms at plug wires. What else needs to be checked or replaced. Gaskets? Thanks, Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,712 #12 Posted January 10, 2016 Have had a bad condenser lead me to believe I had a fuel problem causing the backfiring at certain rpm's. Garry 1 Share this post Link to post Share on other sites
erickson13455 1 #13 Posted February 3, 2016 Well finally got the condenser and installed it. It runs fairly well now. Thanks for the tip. Share this post Link to post Share on other sites
