chorusguy 227 #1 Posted December 26, 2015 Posted here before but can't seem to get a really clear answer. C160 auto creeps forward. I have the manual but it isn't very clear. Need to adjust neutral. Mentions Allen wrench but I don't even see an Allen screw anywhere. Please please help me with this. Thanks Share this post Link to post Share on other sites
stevasaurus 23,456 #2 Posted December 26, 2015 Do you have the Hydro Manual?? Page about 19. You have to remove the cover on the front, the set screw is under that. This is something that I have not done, but the hydro manual seems clear. Share this post Link to post Share on other sites
chorusguy 227 #3 Posted December 26, 2015 OK. Finally sort of figured it out. The manual is pretty useless. Part of the problem is that they identify parts using specific names that aren't intuitive. I had the parts manual so between looking at the exploded view, the owners manual and the tractor I figured it out. There is only one set screw but the manual says "set screws". I got it adjusted but its not perfect. Will give it another shot on a day when I have more patience. At least it doesn't creep in neutral anymore. 3 Share this post Link to post Share on other sites
stevasaurus 23,456 #4 Posted December 26, 2015 Here is what you really want to look at...did not know if you had this.. page like 19 for neutral adjustment. http://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/ 1 Share this post Link to post Share on other sites
chorusguy 227 #5 Posted December 27, 2015 Thanks. Much better picture there 1 Share this post Link to post Share on other sites
608KEB 807 #6 Posted January 3, 2016 (edited) If you can, block the rear wheels. Push your brake in and adjust the allen screw until the wheels will not turn . Test it several times. Edited January 3, 2016 by 608KEB Share this post Link to post Share on other sites
