bds1984
520H M18 repower
bds1984
So, as the title states, I have an early 520H that I've given a new lease on life with a 390-hour M18 engine from a Cub. The only issue I have with this is the PTO shaft is just big enough for the drive pulley and an accessory pulley. Since this engine only has bushings in place of ball bearings,  it cannot accept a tradtional WH PTO. My question is, can I, or is it a good idea to machine a 1.125'' diameter extension to bolt onto the PTO shaft to allow me to put an electric clutch on it?
BESTDOGEVER
I  replaced my 418A  engine  with  a m18  that I  think  was  a replacement  for  a jd that  I  had  used  on a  commercial  powerwasher  that  application  had considerable  side stress  from  the  pump  and the  generator  if you have enough space to attach the  clutch disk and sleeve I  don't  think  that it really would harm the engine  as the magnum series are commercial grade engines and the force of the pto only pushes against the clutch in a straight line.
pfrederi
Some M series came with thrust bearings You have to look up th spec number in the parts manuals to see.  The sideways stresses are handled by two 1 inch long sleeve bushings.  The straight line end loading is the issue and with out a thrust bearing there is only a small lip on one sleeve bushing to handle the loading.  May work for awhile but probably not for long. Insert other media
Edited by pfrederi
JAinVA
If your are talking about butting a 1.125" extension up to the existing shaft I would not do it.The bolt(3/8") if memory serves would be under a load it was not
intended to take.If it got loose or broke you could be eating the clutch assembly.If you were sleeving a 1" shaft then I would do that.The horse could still do
a lot of work without the PTO.JMHO,Luck,JAinVA
can whlvr
I agree with paul,it wont last long,remember the drive pulley will be constantly pulling towards the back of the motor,most of these type engines the crank slides into a pump,or generator,or a transmission
bds1984
Well according to the interwebs and a parts manual, with a spec number of 24647, it should have a thrust bearing so this engine can handle a WH pto.  Now to source out the bits to make that happen.
pfrederi
 I am not so sure about that.
From my read Spec 24647 is crankcase variant #162   Thrust bearings are only in variants 118,120,175,197,206
5689340bd82ab_Washer3.thumb.JPG.8662e86a
bds1984
Well I am glad that you pointed that out.  The reference sheets I found made no mention of specific parts breakdown like that.
pfrederi
Sorry...but you can see that without the thrust bearing the only thing to deal with the end loading (inward pressure ot the PTO) is the tiny flange on the sleeve bearing #23
bds1984
Oh I completely agree and that was my thoughts from the beginning of this project.
