trowbri1
69 Gt14 headlight switch
trowbri1
Anyone have or know where I might be able to locate a headlight switch for a gt14? I'm replacing a broken dash panel and the guy I brought it from replaced the original switch with something else and rigged it up in a new location on the dash. I bought a new panel and need the correct switch to put it in the correct location. The switch it has on it doesn't have holes to mouth it to the dash.
KC9KAS
@trowbri1I installed a new rocker switch on my GT-14. It actually is a 3 position switch being ON-OFF-ON with the 2 different "on" positions powering different light configurations.
The switch did not have mounting holes and the switch covered the mounting holes in the plastic dash plate. It is a "snap- in" type of mount.
I got my switch locally, but you can GOOGLE* "rocker switch 12 volt" and get 1000's of hits and shop from there.
trowbri1
thank you, sir!
