rustyoldjunk 127 #1 Posted December 2, 2008 i think i will make a winter project of mounting my kwik way loader on my 520-8.the only thing that worries me is the tractor frame where it meets/bolts to the trans.i would like some ideas on the best way to build a subframe for the loader.i was thinking maybe the back of the subframe should be directly attatched to the transaxle? maybe the front mount attatched about where the mid tach is? im thinking the factory quick tachs arent strong enough for a fel? so im looking for ideas,suggestions and close up pictures would be great. Share this post Link to post Share on other sites
DMESS 24 #2 Posted December 2, 2008 That's exactly how the KW subframe mounts. Axle housings at the rear, mid attach-a-matic hitch and front attach-a-matic hitch. Plenty strong enough. Share this post Link to post Share on other sites
rustyoldjunk 127 #3 Posted December 2, 2008 thanks DMESS.thats the kind info im looking for.does anyone have pics of the subframe or know where i could find any? Share this post Link to post Share on other sites
Nick 13 #4 Posted December 2, 2008 I'll stop at my brothers and shoot a few pictures of his today. Been wanting to do it for a while and just didnt get around to it. I will add that the subframes do help support the tractors fram and transmission mount. When adding the 3pt to the LR my plan was to also reinforce the trans plate. But after over 2 years of heavy use there wasnt a single crack so I got lazy and didnt weld in an adition support plate. :hide: Share this post Link to post Share on other sites
rustyoldjunk 127 #5 Posted December 2, 2008 thanks Nick,that would be great. Share this post Link to post Share on other sites
Nick 13 #6 Posted December 2, 2008 It was a bit tight in the garage for taking pictures but got a few that are ok. There is a weight frame attached to the subframe with the rear mounting bolt. The same way KW mounts there weight box. Link to more pictures Share this post Link to post Share on other sites
rustyoldjunk 127 #7 Posted December 2, 2008 thanks you very much Nick,thats exactly what i needed.are you going to leave the pictures up a while? i would like to save them but im headed off to work.i could get them copied torrow if you dont mind. Share this post Link to post Share on other sites
Nick 13 #8 Posted December 2, 2008 I dont plan to delete them so no rush for you to copy them. Also if you need more or better pictures of anything I can pull it outside and shoot some more. Share this post Link to post Share on other sites
KyBlue 655 #9 Posted December 3, 2008 Thanks Nick, those should be a help for me too in a couple months Share this post Link to post Share on other sites
