Larry Chamberlain 22 #1 Posted December 17, 2015 I can't Rembeer where I seen it at but I'm looking for a side carb intake I put a bigger motor in my wheel horse and this would be the only way I can put a air cleaner on so can some one please help me out thanks in advance Share this post Link to post Share on other sites
953 nut 62,072 #2 Posted December 17, 2015 Take a look at the GT-14, the air filter mounts on a right angle air inlet tube. Share this post Link to post Share on other sites
Larry Chamberlain 22 #3 Posted December 17, 2015 Where do I find one I can't seem to locate one Share this post Link to post Share on other sites
SylvanLakeWH 29,280 #4 Posted December 17, 2015 (edited) Here's pic of one. Edited December 17, 2015 by SylvanLakeWH Share this post Link to post Share on other sites
953 nut 62,072 #5 Posted December 17, 2015 Post a wanted add in our classified. Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted December 17, 2015 what kind of motor are you using? Share this post Link to post Share on other sites
Larry Chamberlain 22 #7 Posted December 17, 2015 K301 12 hp Share this post Link to post Share on other sites
Larry Chamberlain 22 #8 Posted December 18, 2015 Will this work for my 12 hp k301 block Share this post Link to post Share on other sites
953 nut 62,072 #9 Posted December 18, 2015 7 hours ago, Larry Chamberlain said: Will this work for my 12 hp k301 block Yes, but I think it will turn the air cleaner up rather than to the side. Share this post Link to post Share on other sites
boovuc 1,090 #10 Posted December 19, 2015 The GT 14 intake should work with your K301. Also...........look at some other manufacturers of Garden Tractors that used the Kohler K series. Ariens, Cub, Deere, Gravely, Simplicity, etc. I don't know any specifically but if they had a special need to turn the intake around, chances are it will bolt up to your K301. However, the WH air cleaner assembly will most likely not fit another manufacturer's spec and you may have to use theirs. Just paint it red! Share this post Link to post Share on other sites
Larry Chamberlain 22 #11 Posted December 19, 2015 Ok thanks every one Share this post Link to post Share on other sites
