Howie 900 #1 Posted December 16, 2015 I pulled the transmission apart on this tractor I bought this summer. Wouldn't pull its self. Both axle gears have all the teeth missing and all of the pinion gears are damaged. One of the body plates has a piece broken out around the pocket where the pinion sets. I am wondering if this is going to be too expensive of a repair. I know one of the 1533's doesn't look very good, retainer inside broken one ball floating in there. Looks like all the other gears are ok. Will need some bearings replaced. David Share this post Link to post Share on other sites
Racinbob 12,799 #2 Posted December 16, 2015 Please give us a bit more information. Tractor year, etc. Pictures would help a lot. You likely have the 10 pinion differential. There are options and the folks here will gladly help you out. 1 Share this post Link to post Share on other sites
Howie 900 #3 Posted December 16, 2015 Its a 1972 Raider 12,it is the 10 pinion differential with the 1 1/8 dia axles. . Don't know if I could get pictures on here or not. One of the plates the pinion gears sit in is broken between the gear pockets Share this post Link to post Share on other sites
racinfool40 203 #4 Posted December 16, 2015 I have complete good 10 pinion differentials..axle gears and good 1533 bearings...Sounds like someone got a little ruff with it or used it as a pulling tractor. 3 Share this post Link to post Share on other sites
Howie 900 #5 Posted December 16, 2015 I think a lot of this is from abuse and not taking care of it. Shifter boot non existed and signs it set outside, water in there. I flushed it first and then found out it would't pull its self. When i looked at those 1533's I didn't like what I saw. The ring gear wasn't damaged but the body the pinions go in probably broke from the broken teeth in there. Someone had been in there before because there were no washers on the bolts holding the differential together. I will contact you on the parts. Thanks David Share this post Link to post Share on other sites
squonk 45,590 #6 Posted December 16, 2015 Get another trans. 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #7 Posted December 16, 2015 I also have a complete 10-pinion differential to fit the Raider 12. For details, send email to me here (just clik the link): daveoman@windstream.net Share this post Link to post Share on other sites
Kegler 68 #8 Posted December 17, 2015 You could always swap out the tranny then strip the damaged one for spare parts. 1 Share this post Link to post Share on other sites
Howie 900 #9 Posted December 18, 2015 Yeah, I could do that but used ones never know about all their history.At this point I don't have a whole lot in the tractor because I bought it for the deck. Have a fellow who wanted one. Kind of wanted a tractor for a plow tractor anyway. Got it non running and got engine running and it seems to be decent. Looked on CL and didn't find one very close yet. Share this post Link to post Share on other sites
Irv 115 #10 Posted December 18, 2015 Ditto on looking for a complete. good tranny. Too bad you're not here in Rochester NY. I have 2 of them. Good luck Share this post Link to post Share on other sites
Howie 900 #11 Posted December 29, 2015 Repaired the axle keyway's Saturday and put it back together. Got some parts from racinfool40. Its back under the tractor now and I will have to finish putting the tractor back together. Did test it before bolting it back in. David 3 Share this post Link to post Share on other sites
953 nut 64,267 #12 Posted December 29, 2015 9 minutes ago, Howie said: Its back under the tractor now 1 Share this post Link to post Share on other sites
WHX?? 55,184 #13 Posted December 29, 2015 So where are the ??? Share this post Link to post Share on other sites
Howie 900 #14 Posted January 17, 2016 Finally got rear tires for this, and it will move under its own power. Even tho it is cold had to try it! 1 Share this post Link to post Share on other sites
