marvins 16 #1 Posted December 10, 2015 I have a wheel horse tiller I need a gasket for it. It will be the second time I have had to replace it. The tiller works great but is leaking quite a bit. The number on the tiller is 07-36TL01 10899 0018, I think the tiller is late 70's or 80. I went to parts tree and looked and was no longer available. I think the parts number is 6851. I would like to know where to get one. Also is there anything else to do when I replace it to help keep it from leaking down the road. Thanks for the help Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,764 #2 Posted December 11, 2015 Your tiller is a 1980 model with the 0018 Julian build date Friday January 18, 1980. Manual The gasket changed in 1992 but have no idea if you could make it work. https://www.partstree.com/parts/toro/accessories/07-36tl05-toro-36-tiller-sn-2000001-2999999-1992/ Garry Share this post Link to post Share on other sites
dclarke 4,110 #3 Posted December 11, 2015 Marvin, I just made that gasket for mine out of 1/32" gasket material. I couldn't find the OEM gasket. I'm replacing the seals while I have it apart, I got those at NAPA. Share this post Link to post Share on other sites
