WHX?? 54,453 #1 Posted December 6, 2015 OK guys I admit I am a Onan newbie, before RS I would have dicked around with with this till no end but you guys are hopefully you are my saving grace and will save me some time. When I go from idle to power up the P220 hesitates and often dies unless done slowwwwley, worse cold than when warm but even hot still happens. Tried adjusting the low speed screw and helped but not cured. Idling around 1300-1400 hundred RPM so the 520 tach says. Any advice? Share this post Link to post Share on other sites
lynnmor 8,540 #2 Posted December 6, 2015 Most likely that the carburetor needs cleaned. Check vacuum hoses. If that fails, check for intake manifold leaks between the two halves and all of the intake gaskets. 2 Share this post Link to post Share on other sites
Ed Kennell 44,614 #3 Posted December 6, 2015 clean the carb, again and again till it runs right. Search carb cleaning or onan surging to find details and pictures of how to do the cleaning. Make sure all the holes are open. 2 Share this post Link to post Share on other sites
Shynon 7,533 #4 Posted December 6, 2015 Has the doctor cleared you to work on horses? 2 Share this post Link to post Share on other sites
WHX?? 54,453 #5 Posted December 7, 2015 Ahhh well ahhh. ... and I thought my old lady was gonna bust me..... she did try and help me figure out the blower chute issues...watched over me like a mother hen. Good thing she didn't see me wrastling with that tranny!! I guess the carb work will have to wait 2 Share this post Link to post Share on other sites
Shynon 7,533 #6 Posted December 7, 2015 14 minutes ago, WHX6 said: Ahhh well ahhh. ... and I thought my old lady was gonna bust me..... she did try and help me figure out the blower chute issues...watched over me like a mother hen. Good thing she didn't see me wrastling with that tranny!! I guess the carb work will have to wait Busted 1 Share this post Link to post Share on other sites
WHX?? 54,453 #7 Posted December 7, 2015 Maybe I should get the damned doctor to come work on horses! Then he could be a horse doctor Share this post Link to post Share on other sites
608KEB 812 #8 Posted December 12, 2015 How would you know if the intake gasket was leaking? Share this post Link to post Share on other sites
lynnmor 8,540 #9 Posted December 12, 2015 3 hours ago, 608KEB said: How would you know if the intake gasket was leaking? Spray WD-40 or pump some motor oil along the edge of the gasket, or any suspected leak points, with the engine at idle. You may have to remove some covers to do this. If the gasket is bad, the oil will get sucked in causing a change of speed or sound and possibly exhaust smoke. Be aware that WD-40 is flammable. Use only Onan gaskets for the intake, I have had others fail. 3 Share this post Link to post Share on other sites
