WorkTheHorses 0 #1 Posted December 4, 2015 Good evening all. I hope your enjoying the Lions game as much as I am. I have a C-160 and a C-120. Both are hydrostatic. I have 2 questions I guess. 1. Both tractors have the sunstrand rearend. Are these the exact same transmissions? 2. The C-120 has a manual lift handle, but the C-160 has hydraulic lift. Can I put an 8 speed transmission on the C-120 and put the hydro rearend off the C-120 on the C-160 so I can still utilize my hydraulic lift? If so, how big of a job will it be to convert the C-120? Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted December 4, 2015 The C-120 trans should bolt up to the C-160 no problem but sense it does not have hydro lift on the C-120 the trans may not have the charge pump for the hydro lift???. Putting 8 speed in the C-120 can be a big job if you don't have a parts tractor for all the linkage and foot pedals and all the little bits and pieces but it is possible but may be a bigger job than one may think. Good Luck hope this helps Share this post Link to post Share on other sites
daveoman1966 3,851 #3 Posted December 4, 2015 Whyt not just add the hyd lift kit to the C-120... I have all the parts to do that... takes an hour or so. If you want to pursue this, send direct email to me here...just clik th elink: daveoman@windstream.net Share this post Link to post Share on other sites
