lobo 23 #1 Posted November 30, 2015 While pushing snow, the wet and heavy kind, whenever I had a lot out front, my 161 would just shutdown. It would come back to life on it's own and run fine until the next time. Any thoughts on this? Share this post Link to post Share on other sites
Wishin4a416 2,460 #2 Posted November 30, 2015 Could snow be getting behind your points cover and grounding out? Check to be sure rubber grommet is in place. Just a thought. 1 Share this post Link to post Share on other sites
pfrederi 19,769 #3 Posted December 1, 2015 Look for condensation under the points cover... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,974 #4 Posted December 1, 2015 The engine sits is a rubber mounted cradle. Make sure the ground cable between the engine and the battery is not compromised. Under load the belt may be changing the position of the engine. Garry 2nd thought - Is this a single cylinder or twin? 1 Share this post Link to post Share on other sites
lobo 23 #5 Posted December 1, 2015 Thanks for the thoughts guys, will check everything you mentioned. It is a single cylinder 16hsp, but I did put the chevy points on it, that may be where the problem lies, will silicone around the cover and see if that helps. Thanks again. Share this post Link to post Share on other sites
