Archie 0 #1 Posted November 27, 2015 Hi, can you guys please advise on the battery size for my wheel horse? model # 71188 serial #7900604 brigs # 282707. tx Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,770 #2 Posted November 27, 2015 Will guess it takes a standard sized lawn and garden battery. The operator manual just states 12volt 160 Cold Cranking Amps If you go to the parts list this is the battery Toro would supply https://www.partstree.com/parts/search/parts/?searchTerm=80-2600 You can do better than that locally. Make sure the battery you select has the posts in the same place so your cables will fit. Some are reversed. Take the old battery with you for disposal. There may be an extra charge if you don't have it with you. Garry Share this post Link to post Share on other sites
