D.College 2 #1 Posted November 26, 2015 Guys - looking to purchase a 418A. Looks and runs great. Only problem, seller changed all fluids and the local Simplicity dealer told him to put hydraulic fluid in the differential. I believe it should be 10w30 or 10w40 motor oil. He has not put any real time on it since the fluid change, one hour at the most. Thoughts? Possible damage? Thanks..... Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted November 26, 2015 I think it will be ok as long as it is operating as it should 2 Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted November 26, 2015 @D.College . I too think it will be fine. Just drain the fluid and install a new filter and the proper fluid. 1 Share this post Link to post Share on other sites
953 nut 62,723 #4 Posted November 26, 2015 Most run of the mill hydraulic fluid is 10W non-detergent oil and shouldn't pose a problem if not exposed to excessive heat. As others have said, change to 10W30 and install a new filter and you will be fine. Share this post Link to post Share on other sites
shallowwatersailor 3,216 #5 Posted November 26, 2015 Depending if you are still using dino-oil, I'd do a dump and fill twice. Especially if using synthetic as the final fill. Do a dino and then a synthetic fill. Run it for fifteen minutes between changes perhaps. Share this post Link to post Share on other sites
D.College 2 #6 Posted November 27, 2015 Guys - First let me say thanks to the member who advised "newbie" to enter his question properly! Also thanks for the information concerning the diff fluids. I am going to proceed with my purchase and looking forward to adding the 418 to my stable. The 418 will be a backup as my major "workhorse" is a great 520HC. Looking forward to the 2106 Wheel Horse Collectors Club Show. Thanks again for everyone's input. Dave 1 Share this post Link to post Share on other sites
