WNYPCRepair 1,923 #1 Posted November 20, 2015 I bought these off Amazon. Cheap, but they are still better than the original headlights. I wanted something that would fit in the same holes. http://www.amazon.com/gp/product/B00UYMRNOU?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00 Made a little U shaped bracket, welded the light brackets to it, screwed it to the headlight support. Original wiring intact. My light meter on my phone showed 792 Lux with the originals, 185944 with the new ones. 6 Share this post Link to post Share on other sites
DougC 2,643 #2 Posted November 20, 2015 That's an amazing difference. Well worth the price! How do you think they would work / look on the roof of a cab? Share this post Link to post Share on other sites
WNYPCRepair 1,923 #3 Posted November 20, 2015 That's an amazing difference. Well worth the price! How do you think they would work / look on the roof of a cab? Probably great, the mounts they come with are designed to mount on a bumper or roof. They were only $18 a couple of days ago. Mine came postage due, so the seller had to give me a $9.75 credit. 3 Share this post Link to post Share on other sites
DougC 2,643 #4 Posted November 20, 2015 Oh, I like the way the light is focused. You got those mounted perfectly. Do they seem to be made relatively weather proof in your opinion? Share this post Link to post Share on other sites
WNYPCRepair 1,923 #5 Posted November 20, 2015 Oh, I like the way the light is focused. You got those mounted perfectly. Do they seem to be made relatively weather proof in your opinion? They say waterproof, and they look like they will hold up to normal weather Share this post Link to post Share on other sites
fireman 1,022 #6 Posted November 21, 2015 If anyone has an older Wheel Horse that uses the standard 1156 bulb for headlights, I highly recommend these L.E.D. bulbs as a replacement. Sylvania Zevo Super Bright LED bulbs They are a direct replacement, draw far less current, and are many times brighter then the standard bulb. I just put a pair in John Deere 318 which has 3 bulbs across the front. I only bought one pack and replaced the two outer ones. When I backed the tractor outside at night and turned on the headlights, you could easily see the vast improvement from the two new bulbs over the old middle bulb. Definitely worth the $25 in my opinion. 1 Share this post Link to post Share on other sites
Wishin4a416 2,192 #7 Posted November 21, 2015 Looks good! Brightens things up for sure. Share this post Link to post Share on other sites
Retired Sparky 526 #8 Posted February 23, 2016 On 11/20/2015 at 5:52 PM, DougC said: That's an amazing difference. Well worth the price! How do you think they would work / look on the roof of a cab? Buddy, I think they'd look sweet. On 11/21/2015 at 10:14 AM, fireman said: If anyone has an older Wheel Horse that uses the standard 1156 bulb for headlights, I highly recommend these L.E.D. bulbs as a replacement. Sylvania Zevo Super Bright LED bulbs They are a direct replacement, draw far less current, and are many times brighter then the standard bulb. I just put a pair in John Deere 318 which has 3 bulbs across the front. I only bought one pack and replaced the two outer ones. When I backed the tractor outside at night and turned on the headlights, you could easily see the vast improvement from the two new bulbs over the old middle bulb. Definitely worth the $25 in my opinion. I concur. I replaced a set of 1157's with the Zevo super bright LED"s Works great!!!!!!!!!!!!!! 1 Share this post Link to post Share on other sites
