snowhound 106 #1 Posted November 20, 2015 I've read that Kohler type 1 engines have some lubrication issues mainly when operated on hills or side hills my question is how to I determine if I have a Type 1 engine? I'm asking because I recently purchased a 1974 C-160 which is my oldest Wheel Horse and intended to use it as a worker but would like to know if it has a Type 1 engine before putting it to work.Ed Share this post Link to post Share on other sites
shallowwatersailor 3,214 #2 Posted November 20, 2015 It does have the Type 1, unless it has been replaced along the way. The Type 2 was in production after Kohler found they had warranty issues about the mid '80s.The Type 1 is still a good engine but is only splash lubricated so best to keep it level. Share this post Link to post Share on other sites
snowhound 106 #3 Posted November 20, 2015 Thanks for the reply, I was going to use it for snow removal but my driveway is hilly so the C-160 will go into hibernation. Share this post Link to post Share on other sites
Rob R 977 #4 Posted November 20, 2015 I personally never had a problem, obviously you need to keep the oil properly filled if you are down a 1/2 a quart you may have problems on a 20-30% grade also parking it on a slope and letting the oil drain down the pan probably not a good idea. Share this post Link to post Share on other sites
baerpath 517 #5 Posted November 20, 2015 Unless someone replaced your engine with a twin you should have a K341. The series 1 and 2 are only KT twins. 17,19 and 21hp versions I've never had a problem with KT's either 2 Share this post Link to post Share on other sites
