chorusguy 227 #1 Posted November 19, 2015 Thoughts? Share this post Link to post Share on other sites
Coadster32 793 #2 Posted November 19, 2015 6 of one...1/2 dozen of another. I think the majority may sway you to se-foam. (That all depends on which way the wind blows though) Share this post Link to post Share on other sites
DougC 2,643 #3 Posted November 19, 2015 I use Sta-Bil Store in all mine. 1 Share this post Link to post Share on other sites
shallowwatersailor 3,220 #4 Posted November 19, 2015 (edited) I use MM in my gas as well as Marine Sta-Bil. I like the Seafoam in the aerosol for spraying into running engines.Seafoam does work in certain applications. I had a Volvo that the PCV valve needed cleaning (sucking up the lube oil) but the location of it required five hours of labor. I squirted Seafoam into the vacuum hose using a baby bottle so that I could control the flow to prevent hydro-lock. Cleaned it well enough that I drove it for six more months before trading it. Edited November 19, 2015 by shallowwatersailor Share this post Link to post Share on other sites
mikekot3 93 #5 Posted November 19, 2015 Sta-bil works fine for keeping fuel fresh. For cleaning carburetors and fuel injectors I find Gm recommended Chevron Techron works well.For cleaning combustion chambers I fine GM top engine cleaner works well. 1 Share this post Link to post Share on other sites
JC 1965 1,536 #6 Posted November 19, 2015 I use Seafoam and Sta-bil both but everyone has their opinion. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #7 Posted November 19, 2015 I was thinking about this last night. Seafoam suggests adding it to the oil as well as fuel. That just seems strange to me, putting something that is apparently flammable into my oil. Has anyone done that, and does it seem to do anything? 1 Share this post Link to post Share on other sites
Smokey 30 #8 Posted November 19, 2015 I live out of town and we lose power every so often. In 2009 after an ice storm, It was 16 days before a repair crew got us back online. Because of that I keep 50 gallons of non-Ethanol gas on hand for the generator. I store it with Pri-G and a shot of Sea Foam in each 5 gallon can. I rotate all of through the tractor, mower etc. and I've never had fuel go bad. I use Marvel Mystery oil in my Allis CA gas tank but that's the only engine I use it in. Can't really remember why I started using it in the CA now that I think about it... Share this post Link to post Share on other sites
JackC 617 #9 Posted November 19, 2015 I have a 1996 Buick Roadmaster Wagon with the LT1 engine with 106,000 miles. A check engine light came on indicating an oxygen sensor. I added a can of Seafoam to a full tank of gas and the check engine light went out. I usually add some to the non ethanol fuel I put in my tractors. Share this post Link to post Share on other sites
Sea-Duck51 55 #10 Posted November 20, 2015 Not the same application but remember as a young teen working in an Auto Repair shop the old time Mechanic would rev up the engine and dribble Marvel Mystery Oil down the Carberator,it made a smoke screen large enough to kill a swarm of mosquitos,if I remember right he said it helped free up sticky valves or something. Share this post Link to post Share on other sites
rick 270 #11 Posted November 22, 2015 I use MMM when I fuel the herd with Av Gas, otherwise I use Schaeffer Neutra. Share this post Link to post Share on other sites
clueless 3,347 #12 Posted November 22, 2015 PRI-G, best and cheapest way to stabilize gas IMO. Chris in Florida. 1 Share this post Link to post Share on other sites
Smokey 30 #13 Posted November 22, 2015 I agree, Pri-G has worked much better than Sta-bil for me. I have to order it from Amazon though since I can't find it locally. Share this post Link to post Share on other sites
squonk 45,364 #14 Posted November 22, 2015 On 11/19/2015, 2:54:06, WNYPCRepair said: I was thinking about this last night. Seafoam suggests adding it to the oil as well as fuel. That just seems strange to me, putting something that is apparently flammable into my oil. Has anyone done that, and does it seem to do anything? Ok. First hand account. Brother in law had an Olds with a V-6. Knocked like crazy. I was fixing his brakes when I noticed it. He tells me it's done it for a while. He decides to put Sea Foam in the oil. The knock goes away and never comes back. I buy a Chevy truck with just over 100,000. When hot there is a valve tick, doesn't go away. One day I decide to put a can of Sea foam in the oil. Drive it 3 miles from work to home for lunch. Start the truck to go back and the tick is gone and never came back. 1 Share this post Link to post Share on other sites
clueless 3,347 #15 Posted November 22, 2015 24 minutes ago, squonk said: Ok. First hand account. Brother in law had an Olds with a V-6. Knocked like crazy. I was fixing his brakes when I noticed it. He tells me it's done it for a while. He decides to put Sea Foam in the oil. The knock goes away and never comes back. I buy a Chevy truck with just over 100,000. When hot there is a valve tick, doesn't go away. One day I decide to put a can of Sea foam in the oil. Drive it 3 miles from work to home for lunch. Start the truck to go back and the tick is gone and never came back. Mike, over the past several years I have developed a few knocks and ticks. You think a little sea foam in the Michelob Light might help? -Chris from Florida 2 Share this post Link to post Share on other sites
squonk 45,364 #16 Posted November 22, 2015 It might make it taste like Go Lightly but what the heck. Just get a fresh 8 pack of TP before you do! Share this post Link to post Share on other sites
Wheel-N-It 2,978 #17 Posted November 27, 2015 MMO always along with sta-bil in my (ONLY) non ethanol fuel. Sea Foam when I want to clean the fuel system. Share this post Link to post Share on other sites
Shynon 7,533 #18 Posted November 27, 2015 On 11/19/2015 9:32:24, Sea-Duck51 said: Not the same application but remember as a young teen working in an Auto Repair shop the old time Mechanic would rev up the engine and dribble Marvel Mystery Oil down the Carberator,it made a smoke screen large enough to kill a swarm of mosquitos,if I remember right he said it helped free up sticky valves or something. A little off topic, I had the same experience but we used automatic transmission fluid, poured down the carburetor until the motor stalled. Let it sit a couple hours then start back up and run till it stopped smoking. If nothing else it killed a bunch of Minnesota mosquitos. 2 Share this post Link to post Share on other sites
