rjg854 12,156 #51 Posted February 12, 2016 That's one fine looking machine Share this post Link to post Share on other sites
Cole J. 71 #52 Posted February 12, 2016 Thanks for the help ,welcome and comments. I'm hoping that it will look even better than it dose now just waiting for spring. Share this post Link to post Share on other sites
Phil854 130 #53 Posted February 14, 2016 Just seen this thread looks like you have a great project there. Painting is tough just have fun with the project and do the best you can. Take your time (Iv'e learned that the hard way) WELCOME to I love to vacation down in your neck of the woods enjoy and keep us posted Share this post Link to post Share on other sites
Cole J. 71 #54 Posted February 14, 2016 Yeah I'm definetly not rushing through painting that something i don't want to fix. Share this post Link to post Share on other sites
grine_22 145 #55 Posted February 14, 2016 When you get ready, how are you going to paint it, spray gun or rattle cans? Share this post Link to post Share on other sites
Cole J. 71 #56 Posted February 14, 2016 Initially I was going to do can but my dad said his boss will let us use his gun so I suppose we will do that which is what I was wanting to do because that usually seem to be better looking. Share this post Link to post Share on other sites
Cole J. 71 #57 Posted February 14, 2016 It been a while since I have given a status report on how I have been doing but it really isn't much, just if it wasn't so cold I would do something but anyway I have it stripped down to almost nothing and need to pressure wash it again before primer and paint goes on I had to fabricate a few new pieces. One was the front axial support pin, I don't know whatever you call it. Then the amp meter plate because it was broke in half. Share this post Link to post Share on other sites
grine_22 145 #58 Posted February 14, 2016 4 minutes ago, Cole J. said: It been a while since I have given a status report on how I have been doing but it really isn't much, just if it wasn't so cold I would do something but anyway I have it stripped down to almost nothing and need to pressure wash it again before primer and paint goes on I had to fabricate a few new pieces. One was the front axial support pin, I don't know whatever you call it. Then the amp meter plate because it was broke in half. Did u get a new amp meter plate made already? Share this post Link to post Share on other sites
Cole J. 71 #59 Posted February 14, 2016 I also have a question, on the back of the tractor is a little rod of some sort that sticks out past the back pan, when I toke the pan off the rod wasn't connected to anything and didn't look like it had a place to go. What is this? Share this post Link to post Share on other sites
russellmc301 600 #60 Posted February 14, 2016 to me looks like a hitch pin that hold the hitch in place. 1 Share this post Link to post Share on other sites
Cole J. 71 #61 Posted February 14, 2016 This one wrong pic sorry my phone is being stupid. The first one is the axial pin Share this post Link to post Share on other sites
grine_22 145 #62 Posted February 14, 2016 2 minutes ago, Cole J. said: I believe a more experienced member will chime in but I believe its the lift mechanism going to the hitch. A cable slides through that small pipe and attaches to the hitch and the front goes to the lift handle on the tractor. Share this post Link to post Share on other sites
Cole J. 71 #63 Posted February 14, 2016 11 minutes ago, grine_22 said: Did u get a new amp meter plate made already? Yes I don't have a picture, I couldn't find it I made it a while ago. My organization is terrible I need to regroup everything 2 minutes ago, grine_22 said: I believe a more experienced member will chime in but I believe its the lift mechanism going to the hitch. A cable slides through that small pipe and attaches to the hitch and the front goes to the lift handle on the tractor. Hum could be I'm not sure if that would work though because it dead ends to the shifter box I would have to look at it again Share this post Link to post Share on other sites
grine_22 145 #64 Posted February 14, 2016 14 minutes ago, Cole J. said: Yes I don't have a picture, I couldn't find it I made it a while ago. My organization is terrible I need to regroup everything Hum could be I'm not sure if that would work though because it dead ends to the shifter box I would have to look at it again The picture of the shifter flipped on me for some reason, but the cable drops underneath the panel and goes to the lift lever on my tractor. Share this post Link to post Share on other sites
Cole J. 71 #65 Posted February 14, 2016 All right I will look to marrow maybe that could be since i dont even have a manual shift box it hydrostatic. I will look at that. Share this post Link to post Share on other sites
Racinbob 11,919 #66 Posted February 15, 2016 That cable connecting to the slot hitch runs to the lowest hole on the lift arm rock shaft. It does indeed run through that tube. Share this post Link to post Share on other sites
Cole J. 71 #67 Posted February 15, 2016 That's weird because I don't have that type of hitch, well I suppose it could be interchangeable Share this post Link to post Share on other sites
Racinbob 11,919 #68 Posted February 15, 2016 I suspect you have a drawbar hitch like this based on not having a cable slot hitch clevis hitch Share this post Link to post Share on other sites
Cole J. 71 #69 Posted February 15, 2016 Yeah I have a drawbar Share this post Link to post Share on other sites
Cole J. 71 #70 Posted February 15, 2016 Here is the amp gauge plates the new one is slightly off center but other than that it turned out good I had to Make the old one flat to get a good measurement 2 Share this post Link to post Share on other sites
Retired Sparky 526 #71 Posted February 15, 2016 I've had pretty good luck with NAPA belts. Share this post Link to post Share on other sites
Cole J. 71 #72 Posted February 15, 2016 All right that's good to know thanks Share this post Link to post Share on other sites
russellmc301 600 #73 Posted February 15, 2016 Cole i have that kind of tube thing on a 14 8 speed and i never investigated it now that i think about it. next time ill see what it is. Share this post Link to post Share on other sites
Cole J. 71 #74 Posted February 19, 2016 Well I finally got the steering wheel off the shaft it wasn't as hard as I thought, just a lot of PB Buster. Share this post Link to post Share on other sites
jcp0420 109 #75 Posted February 19, 2016 On 11/20/2015 at 6:42 AM, Cole J. said: What do you guys use for cleaning plastics like the knobs and handles? Project looks great. Keep up the hard work on making it your own! And on the cleaning process.....once you get them cleaned up, to keep the shine use a tire shine product. Spray onto a microfiber and wipe it onto the knob. Make sure its wet and just let it dry. It will keep the knob from getting dirty and will keep the shine on it. Any of the plastics it will work, just don't use it on the seat. Share this post Link to post Share on other sites
