RickF 8 #1 Posted November 15, 2015 Hello, My '69 GT14 trans. (Sundstrand) has developed a leak where the fwd/reverse slide linkage goes into the trans. I want to go into it to stop it. Has anyone else had this problem? Can parts be purchased at any auto parts store or Toro dealer? I'm guessing maybe it's an O-ring? Is there a kit for this, does it need any particular seal? or can I just find things readly available? Thank you for your help. Rick Share this post Link to post Share on other sites
953 nut 59,869 #2 Posted November 15, 2015 Here is the manual for the transmission. It is a Sundstrand 90-2062 model 1-7441 but that part is the same as the 90-2046 used from '68 to '73 on other models.http://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/Open part 4 of this download and you can see some illustrations on pages 50 and 55 that may be helpful. I have not done this particular job, but other "O" Rings I'v replacer on my hydrogear have been standard sizes available at a NAPA store. Hope this helps. Share this post Link to post Share on other sites
RickF 8 #3 Posted November 15, 2015 Thanks Rich, I appreciate that. Share this post Link to post Share on other sites
KC9KAS 4,744 #4 Posted November 16, 2015 The "O" rings are NLA from TORO....I just checked a couple of weeks ago. I ended up with new "O" ring from a bearing shop......and it didn't help the leak problem!Good luck on yours. Share this post Link to post Share on other sites
RickF 8 #5 Posted November 16, 2015 That doesn't sound good. A lot of work to go through, only to still be leaking. Thanks for your help. Share this post Link to post Share on other sites
