Larryr 0 #1 Posted November 29, 2008 Hello all I'am new to the site and just purchased this tractor,.any info would be greatly appreciated! I'am particulary looking for mower deck belt configuration ! Photos are good ! This has the Tecumseh 8 Hp Motor model # HH80-110112D ! I'am normally used to larger tractors, I have a 1952 Ford 8N and Yanmar 2200 ! Thanks Larryr :hide: Share this post Link to post Share on other sites
Duff 207 #2 Posted November 29, 2008 Hi, Larry! I don't know anything about your particular model of tractor, but I wanted to say ! Glad to have you among us, and I'm sure someone with expertise will be along shortly to help out. Oh..... ! We love 'em around here! Duff EDIT: By the way, the 8N is my favorite among "big" tractors. Hope maybe some day to have one! Share this post Link to post Share on other sites
Teddy da Bear 11 #3 Posted November 29, 2008 :hide: Larry! If your looking for the deck belt configuration. You can't use the model number off of the engine. Go to the master parts viewer link. Plug in your model and serial number of your deck https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro You will see a breakdown of the entire mower deck. Including part numbers for each part. It does show the routing too. I bet you have the 36" rear discharge deck. A 36"side dishcharge was also available. A 42" deck was not recommended. Let us know how it goes. Share this post Link to post Share on other sites
Buzz 503 #4 Posted November 29, 2008 If you can't find the model number of your deck, the ones it called for are: 36" rear discharge is # 5-0600 36" side discharge is # 5-0710 Share this post Link to post Share on other sites
Buzz 503 #5 Posted November 29, 2008 Here's a link to the Tecumseh service manual: http://www.mytractorforum.com/images/refer...o18castiron.pdf You can download a transmission manual from Toro. Put 1-0100 for model number and riding mower for product type: https://lookup3.toro.com/request/request.cfm Share this post Link to post Share on other sites
Larryr 0 #6 Posted November 29, 2008 Thanks Duff,Buzz and Teddy Da Bear Very useful info ,but I did not find Belt config. from deck to pulleys to engine Larryr :D Share this post Link to post Share on other sites
Teddy da Bear 11 #7 Posted November 30, 2008 That info is available on the same site. But you must plug your tractor model number in to see that configuration. Share this post Link to post Share on other sites
