Turbo
Junkyard 416-8
Turbo
Picked up a 1989 416-8 from my local scrap yard earlier this week for $100.  Mower deck is shot (I'm looking for optional replacements).  I brought it home, hooked up the battery charger, gave it a shot of ether and it fired up.  So far everything including the lights all seem functional.  It appears this tractor wasn't used much over the past 25 years; however, it doesn't appear to have been well maintained either.  Other than one completely shot rear tire, rusty mower deck, and filters, oil, etc I'm into it pretty cheap so far.
  • Like 6
Brian01
You lucky dog!! :D
Scrap yard charged ya $100 for it though? The guy I haul my scrap to would sale me one for scrap price. ($10-20) But good luck getting a WH in a junk yard round here.
DennisThornton
$10 or $100, you not only got a bargain but you save another Wheel Horse's life!  Because of you 50 years from now it will still be around!
Where you going to buy that kind of power and capability for that kind of money?  And yet they flock to the big box stores everyday...
  • Like 5
953 nut
:WRS:            Good save, That 16 HP Onan is a strong worker. They do need some upkeep so here are a couple of manuals that may help.
http://www.wheelhorseforum.com/files/file/633-tractor-1964-604-654-704-da-om-ipl-wiring-snpdf/
http://www.wheelhorseforum.com/files/file/4367-tractor-1989-400-series-8-speed-om-wiringpdf/
Turbo
Actually I bought it primarily for the transmission.  I thought I'd add it to the project list and someday swap the 8 speed into my 854 tractor.  But once I got it home and seeing how easily it started, I'm very reluctant to part it out now.  I've actually already invested in a new set of rear tires for it too (see my other post about E-Z-Go Backlash tires).  So all said, so far, I'm into it for about $225.  If I can find a better mower deck for a reasonable price, I'm totally happy.
JERSEYHAWG /  Glenn
You have a right to be happy, totally. Best of luck.
Glenn
Wishin4a416
Sounds like you did real good!   Good Luck.
DennisThornton
You'll find another of you feel you must put an 8 in our 854.
Be prepared to pay more for your better deck than you initially paid for your tractor!
953 nut
It sound like you are capable of a bit of backyard engineering; keep in mind that most any deck with a center drive pulley can be used by bolting your :wh: mounting brackets to it.
Turbo
I was actually thinking of that as a question.  This WH deck is rusted out and beat up pretty bad in several places.  I can patch overlaid sheet steel over most of the bad spots and keep it in service, but ideally I'd like to have a better base to start with.  So, 953 nut, are you saying consider even a non Wheel Horse deck?  I do happen to have a late model JD deck from a JD 100 series mower ( I forget the precise tractor number at the moment).  But it is a 2 blade 42" cut versus the 3 blade Wheel Horse deck.  I believe I could somewhat readily attach the WH frame work to the alternate deck if necessary.  Is there any particular alternative brand deck that you know of or have seen as a reasonably acceptable substitute?
Wheel-N-It
Good ending for both you and the Wheel Horse :greetings-clappingyellow:
Tankman
Grandson loves the '85 Kohler powered 416-8 we salvaged some years ago. A "go-to" Stallion!
Edited by Tankman
  • Like 6
953 nut
The only reason I mentioned a three blade deck is that I don't think the belts from the deck will clear the brackets and go around the mule drive if it is a two blade unit.
DougC
$100 won't buy much these days. You however got your moneys worth ++++++++++++++++.               :handgestures-thumbupright:
