Jeff.f
My 654
Jeff.f
Not sure that's enough HP
 some nice kohlers tho, I Like the 9.5 , around $550 tho!  It's on my short list!
AMC RULES
Does look like a good buy on that Lifan though.  :handgestures-thumbupright:
Brian01
For $550 you could buy a decent, complete restorable round hood.
Just sayin' ;)
Edited by Brian01
Jeff.f
Im leaning towards the Lifan,, unless some unknown windfall finds me soon!   Come on 7 come on 11
Jeff.f
Guess I should have posted a pic of where I found it,, it had sat in the same spot in this shape for probably twenty years, never moved,, only thing touched was the cover in the motor , but no one knows when that happened!
C367E94D-423A-4C81-B5CD-58D1C0B0B743_zps
Pullstart
That Lifan looks similar to the Predator, another rip-off of the Honda GX builds.  I have a few of the Predators and I can't complain, but the 6.5 horse didn't fit under my 502 hood without modifications, just so you know.  That's a sweet Chevy!
Jeff.f
Thanks  The Chevy is a blast!
I ordered the Lifan,,  Life is to short to worry about the small things!  I can sell it to someone else later if I find something better!
Jeff.f
Solved most of the problems I know of!
A combination of things that probably both made my Dad sell it for lack of desire to see whats wrong ( He had his own mower!) and also kept it from getting used for the thirty years it set after!
The Woodriff key was gone, the pulley was loose on the shaft and ruined,, showing someone tried to make it go and lastly, the spring broke, where it was,, this was just to much!!!   LOL
 It was hard to push till I got the brake released, now it rolls around like silk!  It's On jack stands now with the front wheels and tires at the store getting new rubber!
Got a new drive belt today,, I hope The motor sets close to the original location,,It may have to be moved back a bit to clear the front grill,,???  not sure yet!  may tilt it slightly back as well, to help with clearance problems!
I found a small spot on the back tires that will cause me to replace them as well,, but they will be fine till spring so I can finish it and play a little,, Maybe find a snow plow too!
953 nut
:twocents-02cents:  That cast aluminum pulley isn't likely to hold up very well.
clip
Jeff, that 41 Chevrolet looks a LOT like my 41 Dodge WC12! Another no frills flat-fendered 4wd beast. I think yours is in quite a bit better shape though!
Jeff.f
Thanks clip!
953 nut ,, I'm guessing your right, it was a quick fix at best but I wanted to get a standard sized pulley for it first, and thats what I found!
  • Similar Content
    • WHX??
      By WHX??
      Yah get yer mind out the gutter @AMC RULES So I have this 1855 snapper in other brands classifieds  and  a guy off  CL bites. Said he has this and  willing to trade. I'm at 750 on the Snapper and thinking 100 against for a who knows what Techy? @Achto  thinks it might be a 654 but thought I would run this by the Pros. Gotta admit it might have that nice barn find patina?
    • cafoose
      By cafoose
      I'm thinking of re-powering my 654 with a predator 6.5 hp. Does anyone know if it fits without major modifications? I'd rather not cut the hood or anything else if possible.
    • zanepetty
      By zanepetty
      Hey guys. I need help finding a steering gear and shaft for my 753. I need it stat! There are a few on eBay that look like they might work but when I ask the seller they don't know can anyone help?? Thanks,
      Zane
    • KC9KAS
      By KC9KAS
      I need some measurement for the shelf/base (what ever you want to call it) that the fuel tank sits on for a 654. I thought I saw the same type set-up on a Lawn Ranger, but don't know the year.
      I have attached a drawing of this piece (that was removed on mine by a PO).
      The end that is inside the hood stand may be slightly narrower than the end where the tank sits.
      Any/All information will be helpful.
      PM me for any additional information.
      Thanks in advance.
      654 diagram.doc
