semper5 43 #26 Posted November 14, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? a spade terminal on the amp meter worked loose, in addition, there were two fuses on the positive side of the meter. One was burnt out.The motorcycl is a beast to start when its cold out, its a 6-cylinder. 2 Share this post Link to post Share on other sites
953 nut 66,608 #27 Posted November 14, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Glad we could help, As you overcome little problems like this you will learn a lot and be able to be of assistance to others. 2 Share this post Link to post Share on other sites
tractorhogg 656 #28 Posted November 15, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? a spade terminal on the amp meter worked loose, in addition, there were two fuses on the positive side of the meter. One was burnt out.The motorcycl is a beast to start when its cold out, its a 6-cylinder. Obviously a case of Hickam's dictum in the case of Wilbur and Occum's razor on the bike Share this post Link to post Share on other sites
WNYPCRepair 1,924 #29 Posted November 15, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? a spade terminal on the amp meter worked loose, in addition, there were two fuses on the positive side of the meter. One was burnt out.The motorcycl is a beast to start when its cold out, its a 6-cylinder. OK, now I have to know. What kind of motorcycle has a 6 cylinder? 1 Share this post Link to post Share on other sites
semper5 43 #30 Posted November 15, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? a spade terminal on the amp meter worked loose, in addition, there were two fuses on the positive side of the meter. One was burnt out.The motorcycl is a beast to start when its cold out, its a 6-cylinder. OK, now I have to know. What kind of motorcycle has a 6 cylinder? Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? a spade terminal on the amp meter worked loose, in addition, there were two fuses on the positive side of the meter. One was burnt out.The motorcycl is a beast to start when its cold out, its a 6-cylinder. OK, now I have to know. What kind of motorcycle has a 6 cylinder?Honda Valkyrie6-cyl.inder, horizontally opposed, 1500cc Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? a spade terminal on the amp meter worked loose, in addition, there were two fuses on the positive side of the meter. One was burnt out.The motorcycl is a beast to start when its cold out, its a 6-cylinder. 2 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #31 Posted November 15, 2015 Nice ride. I didn't realize there was a 6 cylinder bike. Probably a little smoother than my V twin, back in the 70's. Share this post Link to post Share on other sites
tractorhogg 656 #32 Posted November 15, 2015 Looks like 1997-2000 Honda Valkyrie Share this post Link to post Share on other sites
semper5 43 #33 Posted November 15, 2015 Looks like 1997-2000 Honda Valkyrie 2001. Yes, you are correct. Nice ride. I didn't realize there was a 6 cylinder bike. Probably a little smoother than my V twin, back in the 70's. Extremely smooth, runs like a clock. Separate carb for each cylinder. Thank you sir. 1 Share this post Link to post Share on other sites
shallowwatersailor 3,221 #34 Posted November 15, 2015 It's a Two-Wheel Accord. 1 Share this post Link to post Share on other sites
tractorhogg 656 #35 Posted November 15, 2015 It's a Two-Wheel Accord. Accord GT 1 Share this post Link to post Share on other sites
semper5 43 #36 Posted November 16, 2015 It's a Two-Wheel Accord. Accord GT Yea... ok...Has smoked every bike that has taunted me. 2 Share this post Link to post Share on other sites
tractorhogg 656 #37 Posted November 16, 2015 It's a Two-Wheel Accord. Accord GT Yea... ok...Has smoked every bike that has taunted me. Oh I have no doubt, wasn't even trying to dis the Bike, it is a great piece of Iron. Honda always has been a leader in M/Cs. My brother is a big Harley fan, I would be on an old Aspencade in a second over a Harley, I get my rumble fix from my old GTs 1 Share this post Link to post Share on other sites
