semper5 43 #1 Posted November 10, 2015 I tried to use the tractor to jump my Honda Valkyrie today. Then, neither would start. Wheelhorse just quit, and won't respond.C145, newer battery, full tank, no blown fuses that I see. No rresponse from tractor, not even a click. I'm hoping someone might walk me through the steps to get her going. Thanks fo reading. Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted November 10, 2015 Try cleaning your battery contacts...got a good ground? 1 Share this post Link to post Share on other sites
semper5 43 #3 Posted November 10, 2015 I've narrowed it down to the solenoid. Gotta replace it. 1 Share this post Link to post Share on other sites
semper5 43 #4 Posted November 11, 2015 Well, it wasn't the solenoid. Just replaced it, and still, no noises... Share this post Link to post Share on other sites
shallowwatersailor 3,220 #5 Posted November 11, 2015 Like Craig said, check battery connections, and add checking fuses.Manual trans: check safeties and clutch pedal switch.Auto: check safeties and make sure motion lever is in neutral. 1 Share this post Link to post Share on other sites
squonk 45,346 #6 Posted November 11, 2015 If there's an ammeter check the connections. I have seen them burn and then you will have nothing. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,974 #7 Posted November 11, 2015 Download this wiring file. Each circuit has it's own diagram.http://www.wheelhorseforum.com/files/file/670-tractor-1981-c-series-kohler-powered-wiring-detailedpdf/Garry 1 Share this post Link to post Share on other sites
tunahead72 2,600 #8 Posted November 11, 2015 Have you taken a voltage reading on your battery? 2 Share this post Link to post Share on other sites
953 nut 63,897 #9 Posted November 12, 2015 Since the problem began when you hooked up the jumpers to the battery I agree with Craig that the battery cable ends ( both ends ) could be the culprit. After cleaning and tightening all of your electrical connections and checked battery voltage take a small jumper wire from the battery positive terminal to the small terminal on the solenoid; it should turn the starter. If it turns over then you know the solenoid and starter are not the problem.Let us know and we can step by step find the problem rather than looking down every rabbit hole. Share this post Link to post Share on other sites
semper5 43 #10 Posted November 12, 2015 I have removed, cleaned, and tighten the battery connections. The battery is reading 12.55 volts. I used a small wire and touched to positive of battery, and small terminal on solenoid, and it turned. Thank you for helping, I appreciate your knowledge!Whats next gentlemen? Share this post Link to post Share on other sites
WNYPCRepair 1,924 #11 Posted November 12, 2015 Check all the fuses with a meter or test light, check all safety switches. Share this post Link to post Share on other sites
953 nut 63,897 #12 Posted November 12, 2015 Now that we know the solenoid will activate the starter properly the only other components in line that could prevent proper operation are the pedal interlock switch, PTO switch and the ignition switch along with their associates wiring. The PTO switch needs to be off and the pedal needs to be all the way down. Take a look at each to see if any wires have come loose and nothing looks burned. You should have battery voltage to the red wires coming into and out of the PTO switch when the ignition switch is in start and the PTO switch is off. If not, back up to the ignition switch. If battery voltage is present move on to the pedal switch red wires. Let us know what you find. Share this post Link to post Share on other sites
semper5 43 #13 Posted November 12, 2015 The pto switch has been disconnected, and I find no associated wires to ensure they are connected together. In addition, there is no pedal switch either. I've had this tractor since May, and have never had to sit down or depress a pedal to start. My order of starting begins with ensuring the hydro-static control is centered, PTO off, then I start the tractor. All while standing. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #14 Posted November 12, 2015 The pto switch has been disconnected, and I find no associated wires to ensure they are connected together. In addition, there is no pedal switch either. I've had this tractor since May, and have never had to sit down or depress a pedal to start. My order of starting begins with ensuring the hydro-static control is centered, PTO off, then I start the tractor. All while standing. Ah, a hydro. No clutch pedal. Probably the ignition switch would be checked next. Pull the wire bundle off the back and check continuity for each of the positions. Share this post Link to post Share on other sites
953 nut 63,897 #15 Posted November 12, 2015 Did you check the 25 amp fuse as suggested by Brian? Sounds like the previous owner did a bit of rewiring. Having the Hydro control centered is a wonderful thing but is not shown in the wiring diagram. You said the PTO switch is disconnected and later said you make sure the PTO is off, sounds like the wire from the ignition switch may go directly to the solenoid. Since the other switches are no longer there, try taking the small jumper wire from the battery to the "S" (red wire if it hasn't been cobbled too) on your ignition switch, should be the same as touching the small terminal of the solenoid. Share this post Link to post Share on other sites
semper5 43 #16 Posted November 13, 2015 (edited) The 25amp fuse is good.When I stated about the PTO being off, I check to ensure I disengage it before I start it.The wire from the 's' on the switch goes directly to the small terminal on the solenoid. Touching the wire from battery positive to 's' on the switch engages the starter. Edited November 13, 2015 by semper5 Share this post Link to post Share on other sites
953 nut 63,897 #17 Posted November 13, 2015 There is supposed to be a 25 amp fuse on the large red wire from the battery side of the solenoid to the amp meter and then from the amp meter to the ignition switch. Use your volt meter and check for battery voltage at both ends of the fuse (check the condition of the fuse holder), if you only have voltage on the incoming side the fuse is blown. At the amp meter you should have battery voltage at both terminals, At the ignition switch you should have battery voltage at the "B" terminal. If at any point along that path you don't have voltage the wire or component that is between having it and loosing it is going to need to be replaced. Share this post Link to post Share on other sites
semper5 43 #18 Posted November 14, 2015 There is a 25 amp fuse between the ampmeter and the positive side of the battery. There is also an extra 'thing', it is black, it has a 1/4 turn twist lock, and inside is a plastic piece, with metal on both ends. There is no continuity between that to the meter. I've no idea what it is, but, can I cut it out? Since there is a 25 amp fuse already? 1 Share this post Link to post Share on other sites
tractorhogg 612 #19 Posted November 14, 2015 Many times in attempting to diagnosee a problem, be it electrical or mechanical, we often rely on Occum's razor rather than Hickam's dictum in that we attempt to reduce the diagnosis to just one issue rather than what very often is a combination of issues or even coincidences. I have been guilty of this many times and will probably be guilty of it again. The most prevalent reason for failing to properly diagnose the problem is that we are not in a laboratory setting where we have access to a perfect tractor or control group tractor that we can use to manipulate the variables. This becomes problematic with a tractor that is not working, because of the number of working parts involved and the possibility of more than one issue. Electrical, spark, and carb issues seem to lead the way in these issues, but even something as simple as a brake issue can be plagued by this problem, which anyone that has bought a used vehicle may be able to attest too, love those shade tree brake jobs, not. 1 Share this post Link to post Share on other sites
953 nut 63,897 #20 Posted November 14, 2015 YES, that sounds like another fuse holder and fuse, have no idea why the previous owner would put two fuses in series, but the one 25 amp fuse from the factory is all you need. Cut it out and make a good connection on the two wires that went to it. 1 Share this post Link to post Share on other sites
tractorhogg 612 #21 Posted November 14, 2015 BTW, I do not believe the issues with the motorcycle and the tractor are related or the same. Share this post Link to post Share on other sites
semper5 43 #22 Posted November 14, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! 3 Share this post Link to post Share on other sites
tractorhogg 612 #23 Posted November 14, 2015 Removed odd fuse, spliced a good connection, and old Wilbur started right up.Thank you gentlemen for your assistance!! Any idea what caused the problem in the first place or what was wrong with the motorcycle? Share this post Link to post Share on other sites
shallowwatersailor 3,220 #24 Posted November 14, 2015 Many times in attempting to diagnosee a problem, be it electrical or mechanical, we often rely on Occum's razor rather than Hickam's dictum in that we attempt to reduce the diagnosis to just one issue rather than what very often is a combination of issues or even coincidences. I have been guilty of this many times and will probably be guilty of it again. The most prevalent reason for failing to properly diagnose the problem is that we are not in a laboratory setting where we have access to a perfect tractor or control group tractor that we can use to manipulate the variables. This becomes problematic with a tractor that is not working, because of the number of working parts involved and the possibility of more than one issue. Electrical, spark, and carb issues seem to lead the way in these issues, but even something as simple as a brake issue can be plagued by this problem, which anyone that has bought a used vehicle may be able to attest too, love those shade tree brake jobs, not. Love the reference to Occam's razor! 1 Share this post Link to post Share on other sites
tractorhogg 612 #25 Posted November 14, 2015 Many times in attempting to diagnosee a problem, be it electrical or mechanical, we often rely on Occum's razor rather than Hickam's dictum in that we attempt to reduce the diagnosis to just one issue rather than what very often is a combination of issues or even coincidences. I have been guilty of this many times and will probably be guilty of it again. The most prevalent reason for failing to properly diagnose the problem is that we are not in a laboratory setting where we have access to a perfect tractor or control group tractor that we can use to manipulate the variables. This becomes problematic with a tractor that is not working, because of the number of working parts involved and the possibility of more than one issue. Electrical, spark, and carb issues seem to lead the way in these issues, but even something as simple as a brake issue can be plagued by this problem, which anyone that has bought a used vehicle may be able to attest too, love those shade tree brake jobs, not. Love the reference to Occam's razor! I never realized how much people say always and never, or try to point to one cause for dereliction until studying empirical methods and then scientific study steered me straight. This is so prevalent that it is the basis of a large percentage of our economy. people buying things that they believe are broken. Share this post Link to post Share on other sites
