jimkemp 528 #1 Posted November 10, 2015 I cant seem to find the info on a part # for a input shaft seal on a 656 wheel horse trans , does anyone have the # , its a 3/4" shaft and the seal is 1" od Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #2 Posted November 10, 2015 (edited) Your operator manual and illustrated parts listhttp://www.wheelhorseforum.com/files/file/942-tractor-1966-606-656-da-om-ipl-wiring-snpdf/WrongThis is the axle seal and not the input seal that was requested. Correction is below in another post1232 is the original axle seal number. When you first enter the "Transmissions and Transaxles" section here you will see the first 2 posts are pinned. Open the one for bearings and seals to find alternate replacements for the 1232.If you have trouble let us know.Garry Edited November 10, 2015 by gwest_ca Big mistake Share this post Link to post Share on other sites
stevasaurus 23,619 #3 Posted November 10, 2015 That is not the correct seal for the input shaft. It is WH# 1303 which became TORO #100441 and that crosses to SKF #7410. This is for a 3/4" shaft.Garry gave you the number for the seals in your axles (which are 1" dia). BTW if you want to change out your axle seals...that WH#1232 crosses to SKF #9815. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #4 Posted November 10, 2015 Glad you are awake stevasaurus. Thanks for correcting me.Garry 1 Share this post Link to post Share on other sites
stevasaurus 23,619 #5 Posted November 10, 2015 Garry, that is the 1st time for me...usually you are backing me up. Thank You.Actually, I was thinking you read input and it looked like axle. Share this post Link to post Share on other sites
