HorseHead1089 100 #1 Posted November 9, 2015 Thinking about 4x4 a little bit. i have devised a plan, which i will put up some sketches later.Does the brake drum turn in sync with the rear axle speed?Would I be able to secure U joints onto a rear axle of the transmission and have them turn nice side to side with properly aligned knuckles?Im thinking if I use a manual trans case i could use a remote locking diff like Apreig Did on youtube for the front and also borrow the brake drum sprocket idea. Share this post Link to post Share on other sites
C-101plowerpower 1,606 #2 Posted November 9, 2015 go and do a search for project c4 and project bendy. most answers to your questions are there 1 Share this post Link to post Share on other sites
meadowfield 3,177 #3 Posted November 10, 2015 brake drum runs at 12:1 from the axle.Yes you could use UJ's - watch this space... Share this post Link to post Share on other sites
