persof 14 #1 Posted November 9, 2015 My 1988 312-8 quit running today. Before it quit completely I got it to run weakly with full choke so I suspected crud in the carb. I took the bowl off and removed a fair amount of crud, squirted cleaner thru the main jet and figured my troubles were over but it would not run at all with out starting fluid. I removed the line going from the fuel pump to the carb and cranked the engine and nothing came out. If I lower the line below the tank level fuel pours out so the line from the tank is OK. I removed the fuel pump and worked the lever with my finger over the inlet and did not feel any suction. Is there a rebuild kit? Is there a diagram that shows how it is assembled? All suppliers say "no longer available"Any Ideas??Francis Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted November 9, 2015 Here is a Stens pumphttps://www.bantasaw.com/catalog/viewproduct.asp?i=&p=7645The one currently available from Kohler is 47 559 11-SGarry Share this post Link to post Share on other sites
N3PUY 1,031 #3 Posted November 9, 2015 Take the pump apart. It may just be dirt in the pump. I had one full of rust ... cleaned it out and it worked fine.What can it hurt.Joe Share this post Link to post Share on other sites
BESTDOGEVER 218 #4 Posted November 9, 2015 If cleaning it doesn't work they're available on amozon for about 30-35 bucks the cheap ones are the same as the 100 dollar ones from kohler 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #5 Posted November 10, 2015 Then -now-auto.com makesRebuild kits for kohler fuel pumps. Share this post Link to post Share on other sites
953 nut 63,096 #6 Posted November 10, 2015 An electric fuel pump from a US seller on will run you $ 20 or less and work well. Share this post Link to post Share on other sites
BESTDOGEVER 218 #7 Posted November 10, 2015 If the replacement works as well as the first it should outlast any of us I got 27 years out of the first one. Over the years I cleaned it a few times and filled it with oil to keep the rust down and soften the diaphragm. The new one is made here by a oem supplier it looks and works like the original. Share this post Link to post Share on other sites
persof 14 #8 Posted November 12, 2015 I sprung for a new one from Kohler for $156 (OUCH) but even though the engine now runs it acts like its not getting enough fuel if the engine is under heavy load for more than 3~5 seconds?Is there a fuel flow test? I replaced the fuel filter the same time as the pump. Turning the main jet (which was fine before) a 1/2 turn rich made no difference.How much fuel should this thing pump at what RPM???ThanksFrancisI will be looking at http://then-now-auto.com/kohler-fuel-pumps-2/ If cleaning it doesn't work they're available on amozon for about 30-35 bucks the cheap ones are the same as the 100 dollar ones from kohler Share this post Link to post Share on other sites
mikekot3 93 #9 Posted November 12, 2015 Hello Francis,Thanks for sharing the website. Share this post Link to post Share on other sites
Horse46 519 #10 Posted November 12, 2015 on that link, I may need to visit there too. Share this post Link to post Share on other sites
BESTDOGEVER 218 #11 Posted November 12, 2015 Check the gas cap and screen on the shut off Share this post Link to post Share on other sites
WH nut 553 #12 Posted November 13, 2015 I sprung for a new one from Kohler for $156 (OUCH) but even though the engine now runs it acts like its not getting enough fuel if the engine is under heavy load for more than 3~5 seconds?Is there a fuel flow test? I replaced the fuel filter the same time as the pump. Turning the main jet (which was fine before) a 1/2 turn rich made no difference.How much fuel should this thing pump at what RPM???ThanksFrancisI will be looking at http://then-now-auto.com/kohler-fuel-pumps-2/ If cleaning it doesn't work they're available on amozon for about 30-35 bucks the cheap ones are the same as the 100 dollar ones from kohler Did you properly adjust the carb after you had it a part? Share this post Link to post Share on other sites
BESTDOGEVER 218 #13 Posted November 13, 2015 Just a thought did you check the fuel line it might be collapsing . The ethanol in the gas will rot them pretty bad Share this post Link to post Share on other sites
