mrc 1,116 #1 Posted November 1, 2015 hi men, going thru a wh tractor for a friend. i noticed that the drawbar pin had no snap rings or e-clips holding it in. UH-OH! boy was that pin stuck. penetrating oil and my oxy-acetylene torch would not help free it. in desperation i cut it as close as possible to the unidrive tranny case. using a thin cutoff wheel on an angle grinder i sanded it flush with the case. then i used my ball joint C-press kit with a 5/8 bolt that i cut the head off. it managed to push it out. what a relief! good tools are priceless. i mention this in hopes it helps one of you unstick one of those buggers. used lots of anti-sieze on the new one going back in. best regards to all mike in mass. 6 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted November 1, 2015 Thanks for another idea to remove these @#$!%#@ pins! Share this post Link to post Share on other sites
woodchuckfarmer 333 #3 Posted November 1, 2015 A ball joint press dose wonders on the pins. Put a SS pin back in , then no more problems. 1 Share this post Link to post Share on other sites
Pullstart 71,193 #4 Posted November 4, 2015 I made sure to wire brush the inside of the trans hole too when I put mine back together. Luckily a couple ball peen hammers and some map gas did the trick to get mine loose. Reminds me I still need oxygen and argon tanks filled! Share this post Link to post Share on other sites
cleat 9,324 #5 Posted November 4, 2015 I had a C160 that I sold to my neighbor a couple years ago that had a grease fitting on the trans where that pin goes through.That pin just slid out.Cleat 1 Share this post Link to post Share on other sites
Xjchief 128 #6 Posted November 4, 2015 another good tip that i just used on two of mine that were stuck is a pipe wrench. soak it first of course ,grab a 2 footer, the jaws seem to fit just right and get a nice tight grab on it. best of all didnt waste the pin. 2 Share this post Link to post Share on other sites
JackC 619 #7 Posted November 4, 2015 The anti-sieze is a good thing. Your experience is a good reminder for all of us to lube everything as part of routine maintenance understanding that these machines were made to be around for a very long time. 1 Share this post Link to post Share on other sites
DougC 2,644 #8 Posted November 4, 2015 The anti-sieze is a good thing. Your experience is a good reminder for all of us to lube everything as part of routine maintenance understanding that these machines were made to be around for a very long time. Yes I agree completely. I never install spark plugs or oxygen sensors without using anti-sieze compound on the threads. For that matter anything exposed to the elements you may ever want to remove in the future.............. Share this post Link to post Share on other sites
Pullstart 71,193 #9 Posted November 4, 2015 The big three should get the hint that anything sold in the rust belt should have anti-seize pre-applied. I would love them, as would so many other backyard warriors! Share this post Link to post Share on other sites
953 nut 69,062 #10 Posted November 4, 2015 The big three should get the hint that anything sold in the rust belt should have anti-seize pre-applied. I would love them, as would so many other backyard warriors! They won't do that, it might cost them money! Share this post Link to post Share on other sites
Tankman 3,528 #11 Posted November 5, 2015 A ball joint press dose wonders on the pins. Put a SS pin back in , then no more problems. Always use Never-Seez too! When rebuilding I try to use all SS hardware and Never-Seez. http://www.bostik-us.com/our-brands/never-seezMade a few mower decks, under the Rustoleum Regal Red were all 316 SS. Share this post Link to post Share on other sites
cleat 9,324 #12 Posted November 5, 2015 Wow, I would love to have a 316 deck. That thing would last forever from a rust standpoint. Share this post Link to post Share on other sites
cleat 9,324 #13 Posted November 5, 2015 Wow, I would love to have a 316 deck. That thing would last forever from a rust standpoint. Wow, I would love to have a 316 deck. That thing would last forever from a rust standpoint. Wow, I would love to have a 316 deck. That thing would last forever from a rust standpoint. Share this post Link to post Share on other sites
Tankman 3,528 #14 Posted November 5, 2015 (edited) Wow, I would love to have a 316 deck. That thing would last forever from a rust standpoint. I was a prototype sheet metal mechanic (70's), had carte blanche to build anything I wanted. Had aluminum, CRS (cold rolled steel) but most of the chemical tanks** I worked with were 316 SS. I used heavier gauge 316 stainless steel mostly everywhere.I had a couple of finished decks on my trailer, painted. Dealer loved the work but was confused when I said, "Here, try this magnet on 'em." Wouldn't stick of course.PS. **That's why I'm called Tank or Tankman. Edited November 5, 2015 by Tankman 4 Share this post Link to post Share on other sites
ronhatch 410 #15 Posted November 5, 2015 I always wondered why some of the better garden tractor manufacturer didn't use SS on their decks. Share this post Link to post Share on other sites
Tankman 3,528 #16 Posted November 5, 2015 I always wondered why some of the better garden tractor manufacturer didn't use SS on their decks. $$$$ That's why. We used the SS for chemical resistance although we used more materials too; i.e.: titanium and hastelloy.Always keep some brass drift pins in the tool box for tappin' out stuck pins. Share this post Link to post Share on other sites
cleat 9,324 #17 Posted November 5, 2015 We use a lot of 316 SS, 304 SS at work and the more highly corrosive areas get Hastelloy 276 or Inconel.Great stuff but extremely pricey. A deck made of Hastelloy would last forever. Making it would be a pain, that stuff is hard to cut and machine.Cleat Share this post Link to post Share on other sites
Tankman 3,528 #18 Posted November 5, 2015 (edited) Made a lot of "home jobs" Cleat. Usually 316 SS for my Stallions, they love it!Decks I used 12 ga or 10 ga 316L, lots of 1/4" SS flatbar for reinforcement when required or when I felt like it.Made a few snow blades with mounts. Never any rust. Of course SS hardware and still used Never-Seez on all threads. Edited November 5, 2015 by Tankman Share this post Link to post Share on other sites
cleat 9,324 #19 Posted November 5, 2015 Good to use Never-seize on SS. SS loves to gall and Never-seize will help prevent that.Cleat Share this post Link to post Share on other sites
tunahead72 2,662 #20 Posted November 5, 2015 Tankman, you're a tease, where's the SS photos? Share this post Link to post Share on other sites
DennisThornton 4,773 #21 Posted November 5, 2015 The anti-sieze is a good thing. Your experience is a good reminder for all of us to lube everything as part of routine maintenance understanding that these machines were made to be around for a very long time. Yes I agree completely. I never install spark plugs or oxygen sensors without using anti-sieze compound on the threads. For that matter anything exposed to the elements you may ever want to remove in the future.............. Love anti-seize and everything I think might need to be removed sometime, by myself or others! Share this post Link to post Share on other sites
