ebrickley 7 #1 Posted October 29, 2015 I have a 1978 Wheel Horse C141 with a Kohler 14 hp K321AS engine. I have only had it for about a month and did a garage restore on the body. Going to change fluids now and when I unscrewed the oil filler plug, there was no dipstick attached. I looks like the previous owner (who really rigged some things up), must have lost the original. Does anyone know if there is an external tube dipstick for this model? Also, should the filler plug have a dipstick attached to it?Thanks for the help!Ed Share this post Link to post Share on other sites
redhead 10 #2 Posted October 29, 2015 I have a 1979 c-141, 14H.P.321As and it has a dipstick in it Share this post Link to post Share on other sites
ebrickley 7 #3 Posted October 29, 2015 is the dipstick attached to the plug or is it an external tube with a dipstick? Share this post Link to post Share on other sites
doc724 925 #4 Posted October 29, 2015 I have a 1979 c-141, 14H.P.321As and it has a dipstick in it I also have a 1978 C141 and it has the external tube with a dipstick. I recently restored a C101 and it had the plug with the attached dipstick. Check to see if Davoman here on RS might have one available. I have a 1979 c-141, 14H.P.321As and it has a dipstick in it I also have a 1978 C141 and it has the external tube with a dipstick. I recently restored a C101 and it had the plug with the attached dipstick. Check to see if Davoman here on RS might have one available. Share this post Link to post Share on other sites
ebrickley 7 #5 Posted October 29, 2015 I will check with Davoman....THANKS! Share this post Link to post Share on other sites
MalMac 1,333 #6 Posted October 30, 2015 It should have the external dip stick tube. If it only has the plug that screws into the block, it will have a dip stick pressed into the plug. Some were tack welded. If stick is missing out of the plug, good chance it might be down in the motor. If it's the plug type good chance also it's not the original motor on the C-141, I have had a dip stick come out of a plug and fall down in a motor and it never made a sound. Be careful if that's the case. Share this post Link to post Share on other sites
ebrickley 7 #7 Posted October 30, 2015 Hey doc724 and redhead...can either one of you give me a measurement off of your dipstick? I am looking for the measurement of the tip to the rubber grommet.Thanks! Share this post Link to post Share on other sites
Marv 994 #8 Posted November 1, 2015 I will measure mine tomorrow and post it for you.Marvin Share this post Link to post Share on other sites
Marv 994 #9 Posted November 3, 2015 The dipstick measurement you requested is 14 inches.Marvin Share this post Link to post Share on other sites
