tractorhogg 642 #1 Posted October 28, 2015 If two of these were put together would they work as a rear PTO coupler on the D series tractors? They are 1" by 15 spline.http://www.paulbparts.com/drivelines/weasler-north-american-series/weasler-6-series-pto-shaft-par/weasler-6-series-pto-tracto-7 Share this post Link to post Share on other sites
JackC 618 #2 Posted October 28, 2015 (edited) Not sure what you are asking.Are you trying to plug something into the rear rotating PTO? Edited October 28, 2015 by JackC Share this post Link to post Share on other sites
Brian01 481 #3 Posted October 28, 2015 Yeah I believe he's trying to make a yoke coupler. Like on a bruh hog or w/e Share this post Link to post Share on other sites
tractorhogg 642 #4 Posted October 28, 2015 Yeah, my rear PTO doesn't have a coupler, and seeing how they seem to be hard to find, I thought I would try a different route. Share this post Link to post Share on other sites
Brian01 481 #5 Posted October 29, 2015 If you have an actual PTO shaft that comes out the back, then yeah you could use something like that. Share this post Link to post Share on other sites
tractorhogg 642 #6 Posted October 29, 2015 If you have an actual PTO shaft that comes out the back, then yeah you could use something like that. I do have a rear PTO shaft, if I didn't have the rear shaft the coupler wouldn't attach to anything. Is that what your trying to say?English isn't my first language, so sometimes I do not quite understand the vernacular English, In German everything is put in direct terms because there isn't alot of deviance with grammar or syntax, unless using slanglish Share this post Link to post Share on other sites
Brian01 481 #7 Posted October 29, 2015 Just giving my , someone sweep in here n save me!! 1 Share this post Link to post Share on other sites
tractorhogg 642 #8 Posted October 29, 2015 Lol. Brian. I do understand that I must have a rear PTO to need a coupler. Its kind of like I wouldn't need a muffler if I had a solar car. Clear as mud as to what you said, I just wasn't sure what JackC meant and I don't think he understood what I was say and then the confusion spread to all. Share this post Link to post Share on other sites
JackC 618 #9 Posted October 29, 2015 (edited) Most of the attachment I am familiar with, like the field mower for the rear end, and the snow blower for the front end, have shafts that slide into the rear PTO or the front PTO. The shaft then goes to a universal joint. I assume you could make a coupler but it would need to be very strong to withstand the torque. One end of the coupler would need a shaft to slide into the rear PTO. There may be a Category 0 rotating PTO coupler available from a tractor dealer or from somewhere. You could also make a coupler from a universal joint.What are you trying to attach? Edited October 29, 2015 by JackC 1 Share this post Link to post Share on other sites
Niagara D 11 #10 Posted October 29, 2015 My rear pto shaft is also missing the quick connect coupler that came with these shafts but one of the PO had just changed up the drive to the rear deck to slide over the pto shaft spines and there would be a spring inside that drive shaft to the implement. 1 Share this post Link to post Share on other sites
JackC 618 #11 Posted October 29, 2015 (edited) There are two threads one here and one under implements and attachments. Can a moderator fix it?Sounds like you are missing the female coupling end if all you have is the male end.I will need to find a parts diagram. Edited October 29, 2015 by JackC 1 Share this post Link to post Share on other sites
JackC 618 #12 Posted October 29, 2015 (edited) If all you have is the male end of the rotating PTO, I would look for a spline drive clamp on coupler. They are often used when connecting to hydraulic pumps that have splined shafts. That would give you something to attach to. Something like below: Edited October 29, 2015 by JackC Share this post Link to post Share on other sites
tractorhogg 642 #13 Posted October 29, 2015 Thanks a bunch Jack, the two tabs on the front would not attach to anything, or would they? If not would it hurt to cut them off? There are two threads one here and one under implements and attachments. Can a moderator fix it?Sounds like you are missing the female coupling end if all you have is the male end.I will need to find a parts diagram. Wonder how two threads started, I idn't think it was me, but it sure might have been, weird. I have a parts diagram Most of the attachment I am familiar with, like the field mower for the rear end, and the snow blower for the front end, have shafts that slide into the rear PTO or the front PTO. The shaft then goes to a universal joint. I assume you could make a coupler but it would need to be very strong to withstand the torque. One end of the coupler would need a shaft to slide into the rear PTO. There may be a Category 0 rotating PTO coupler available from a tractor dealer or from somewhere. You could also make a coupler from a universal joint.What are you trying to attach? I havent' attached anything yet, I was hoping to use a finish mower or brush hog Share this post Link to post Share on other sites
Jim_M 179 #14 Posted October 29, 2015 John Deere used the same coupler as the D series on some of their larger garden tractors. You might want to check for a John Deere coupler, I'll bet they're still available.. 1 Share this post Link to post Share on other sites
tractorhogg 642 #15 Posted October 29, 2015 Thanks for the info Jim Share this post Link to post Share on other sites
