dgjks6 8 #1 Posted November 26, 2008 My 312-8 with a magnum 12 has always run almost perfect. Two days ago I shut it off during plowing and it had the LOUDEST backfire I have ever heard. After that the engine had a hard time restarting. Since then, it starts normal when cold, but when restarting after it is warm it had a hard time restarting. Sometimes I even have to use a little choke to get it to go. Anyone have any ideas. Greg Share this post Link to post Share on other sites
refracman 167 #2 Posted November 27, 2008 Well if'ins it was a ol' holley i'd say the power valve blew, but since its most likely a walbro hmmmm. could of bent the exhaust valve, maybe but not likely. could also be the float sticking . but im just guessing , hopefully somebody else will chime in Share this post Link to post Share on other sites
linen beige 16 #3 Posted November 27, 2008 I'm gonna guess, and only guess, that maybe it's time to de coke the cylinder. Something ignited gas to make it backfire. Probably carbon in the combustion chamber? If there is a build up then when it is hot the carbon can hold enough heat to burn the fuel as it enters the cylinder before it gets compressed so it won't start. Could be that using the choke richens it up just enough to overcome this? Might also be as simple as being slightly out of time. Share this post Link to post Share on other sites
Jim_M 179 #4 Posted November 27, 2008 I would do a compression test. It sounds like the head gasket blew. That will cause them to start hard when warm. Share this post Link to post Share on other sites
dgjks6 8 #5 Posted November 27, 2008 I cleaned the head this summer and replaced the head gasket, so I know there is no build up in the combustion chamber. I may just replace the head gasket then. It costs almost nothing and takes only a few minutes. Can I replace the head gasket in the cold? Do the bolts get more brittle? Should I use the same torque? I work in an unheated garage. Greg Share this post Link to post Share on other sites
Jim_M 179 #6 Posted November 27, 2008 Greg, The temperature won't matter. Just do it like you did last time and you should be fine. Jim Share this post Link to post Share on other sites
dgjks6 8 #7 Posted November 27, 2008 Thanks Jim, Last question. When I did it last time they said no gasket sealer. Should I use some this time? Greg Share this post Link to post Share on other sites
sorekiwi 761 #8 Posted November 27, 2008 No sealer, I just put em on dry. Some people swear by silver aerosol paint, but I'm (very) unconvinced... Share this post Link to post Share on other sites
KyBlue 655 #9 Posted November 27, 2008 when I put a big motor together, I use the Copper spray.. probably does the same thing as paint, but.. I like the added protection to fill in any surface knicks, or deep scratches.. Should be available @ ur local parts store that carries permatex stuff.. Share this post Link to post Share on other sites
Jim_M 179 #10 Posted November 28, 2008 To be honest I've put them together dry and with Indian Head Copper head gasket paint and couldn't tell a difference. If you put it together dry it will be easier to clean up if you ever have to tear the engine down for a rebuild. Share this post Link to post Share on other sites
HorseFixer 2,015 #11 Posted November 28, 2008 when I put a big motor together, I use the Copper spray.. probably does the same thing as paint, but.. I like the added protection to fill in any surface knicks, or deep scratches.. Should be available @ ur local parts store that carries permatex stuff.. I have used the silver paint in the past with good results, I may pick up a can of that copper stuff cause my Toro 8hp has a briggs and It has a blown head gasket that I need to fix, think Ill give that a try :hide: Share this post Link to post Share on other sites
