Snowmobileaddict
Need a Couple 5xi Subframe Dimensions for Kwikway FEL
Snowmobileaddict
If anyone has 10 minutes and a 5xi kwikway loader subframe to grab (5) dimensions from, it would be a big help.  Trying to build one of these and not having much to go on is a pickle.
What I am looking for is illustrated in the photo in this post.
Detailed descriptions of each are as follow:
A: The dimension from the centerline of the mid-mount quick-tatch pin to the bottom of the longitudinal subframe member
B: The dimension from the top of the forward subframe mounting bracket to the bottom of the longitudinal subframe member
C: The setback dimension from the front edge of the forward subframe to the front edge of the subframe cross-member (this determines where the loader sits on the tractor front-to-back).
D: The dimension from the bottom of the subframe crossmember to the bottom of the right side upright receiver.
E. Height dimension of subframe longitudinal subframe member
THANKS!!!
Edited by Snowmobileaddict
typo
doc724
Going grocery shopping now.  Will be back in about 2hrs and then I will give you the measurements.  I will also give you the measurements of the structural steel.
Snowmobileaddict
Don,
Thanks Much!
Really glad to hear you can help.
Andy
