chorusguy 227 #1 Posted October 17, 2015 So. Here's what I have. C160 auto. And a 12" moldboard plow. When I plow with my right wheels in the furrow I get about a 4" gap that is untouched by the plow. I have the plow adjusted all the way to the right but it is still giving me a gap. I researched the plow manuals here and am not getting much help. I did notice that in the earlier manuals a 12" plow was not listed for use with a tractor that has a distance of18" between the rear wheels which is what mine is. Could this be the problem? Could it be that I am plowing too deep or too shallow? The adjustment bolts in the clevis hitch are out. Seems that I read with a plow you shouldn't tighten them. Really puzzled and a little frustrated. The plow is not a wheelhorse plow if that matters. Please help. Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted October 17, 2015 This sleeve hitch is centeredAnd your hitch is like thisYou may need to remove the 2 bolts that hold the hitch onto the plow and turn it over so the entire plow is moved over to the right. 3 Share this post Link to post Share on other sites
chorusguy 227 #3 Posted October 17, 2015 Someone else suggested that but it is welded. I looked up the manual for a brinly plow and there is some adjustment for a plow tracking too wide. When I get home I will see if mine has that adjustment Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted October 17, 2015 You are saying this piece with the 3 holes (that looks bolted to the plow) is welded? Grind the weld off, remove the bolts, turn the hitch over, replace the bolts and try it again. 1 Share this post Link to post Share on other sites
