jimkemp 528 #1 Posted October 17, 2015 Can someone tell me if the seal on the brake shaft is the same as the axle on a 656 , my axle is 1" and so is the brake drum shaft Share this post Link to post Share on other sites
rmaynard 16,782 #2 Posted October 17, 2015 They are the same. Do you need a part number? Share this post Link to post Share on other sites
slammer302 2,156 #3 Posted October 17, 2015 Should be Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
rmaynard 16,782 #4 Posted October 17, 2015 The old Wheel Horse part number is 1232. That number was superceded by Toro #100863. You can get them locally from auto parts stores as SKF9815, or CR9815. 2 Share this post Link to post Share on other sites
jimkemp 528 #5 Posted October 17, 2015 They are the same. Do you need a part number? Thanks but I have axle seals for it I just wanted to make sure they are the same before I dig the old seal out , thanks everyone for the help 1 Share this post Link to post Share on other sites
ronhatch 410 #6 Posted November 1, 2015 Do those numbers for the oil seal apply to my 1979 C-101 8 speed as well? thanks. Share this post Link to post Share on other sites
stevasaurus 23,536 #7 Posted November 1, 2015 If it is a 1" shaft...it is the same seal. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #8 Posted November 1, 2015 (edited) Do those numbers for the oil seal apply to my 1979 C-101 8 speed as well? thanks. Should have a 1-1/8" diameter axles unless the trans has been changed - some do have 1" axles.http://www.wheelhorseforum.com/files/file/2388-transmission-gear-uni-drive-6-forward-speeds-1125in-8-pinion-6g-103916-1978-1984-iplpdf/Garry Edited November 1, 2015 by gwest_ca Share this post Link to post Share on other sites
