sdhdcouple 133 #1 Posted October 16, 2015 If they did and if someone is good at trouble shooting them, I have a problem child. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,974 #2 Posted October 16, 2015 The 518xi used a CH18 and Toro used many CH20 models which I believe are the same design.Garry Share this post Link to post Share on other sites
boovuc 1,090 #3 Posted October 18, 2015 I think some Commands went into the higher-end zero turns also. Share this post Link to post Share on other sites
sdhdcouple 133 #4 Posted October 18, 2015 ya I have one that is not firing on 1 side, and I have never had one before this. so trying to figure it out as I go Share this post Link to post Share on other sites
stevasaurus 23,565 #5 Posted October 18, 2015 (edited) You can download the Manual at this site. Select "command pro" HSP "16-20" Shaft "horizontal" and scroll down.http://www.kohlerengines.com/manuals/landing.htm Edited October 18, 2015 by stevasaurus Share this post Link to post Share on other sites
shallowwatersailor 3,220 #6 Posted October 18, 2015 There are a few manufacturers that use this engine. Simplicity, for example, uses it in the Legacy model so you may want to check other forums for hints as well. Which Toro Wheel Horse model do you have? The CH18 and CH20 engines are the same, just an adjustment on the governor for the "2 hp" difference and labels.This engine uses individual coils for the cylinders. Worse case scenario is that mice got in behind the shroud and had lunch. Use the search function on RS to look for similar issues. 1 Share this post Link to post Share on other sites
sdhdcouple 133 #7 Posted October 18, 2015 well mine CH18 does happen to be on a Argo/Allis 918 tractor. Not trying to down play anyone on Allis/simplicity sites, but of all the forums I follow, the people here seem to be a thorough and helpful bunch. I thought I would ask here to see if Wheel Horse was had the same issues with the motor and get more input. the more info I can gather the better I can try to fix this motor, as I am dumb and blind on this CH motor. Share this post Link to post Share on other sites
wildman 205 #8 Posted October 19, 2015 I would swap the coils side to side.Side without spark gets spark then you know its a bad coil Share this post Link to post Share on other sites
sdhdcouple 133 #9 Posted October 19, 2015 ya I had to take the motor out of the ting to even get to them. pain in the butt Share this post Link to post Share on other sites
sdhdcouple 133 #10 Posted October 19, 2015 well I hope someone makes them after market, Kohler no longer makes them Share this post Link to post Share on other sites
shallowwatersailor 3,220 #11 Posted October 19, 2015 Try this, if it is the module.http://www.jackssmallengines.com/Parts-Lookup/2458445S/753115/ps?gclid=CL7ZgrGYz8gCFVUWHwodU1MK3g Share this post Link to post Share on other sites
sdhdcouple 133 #12 Posted October 19, 2015 Ok as advised I switched the coils and the one is bad. And after seeing the jacks posting I s I had entered the number in wrong. Just been one of those days. But at least we might get problem one fixed and cross the fingers maybe it will fix them all. LOL 1 Share this post Link to post Share on other sites
