stevecobb76 19 #1 Posted October 11, 2015 After i did a little research online. The inside of hydraulic pump looks identical to a couple pressure washer pumps that I have rebuilt.can anyone tell me why I could not interchange them?my thought is that the oil is thicker and if I ran it through a pressure washer pump, it would probably be harder on the pump itself and possible make higher flow / pressure than rated at the cost of more wear and tear on the pump itself???but why could I not use a 1500 psi or 2500 psi pressure washer pump for a hydraulic system on a tractor with hydraulic oil????I know, off the wall. but I have 4 of these pumps just sitting there on my bench. and I have a 4000 and 3500 already running so I dont need the extras. Share this post Link to post Share on other sites
doc724 925 #2 Posted October 11, 2015 Seals might be the problem. Different fluids require different elastomers. I am not familiar with high pressure water pumps. How much CFM can a high pressure water pump deliver and how does that match up to the needs of a oil based hydraulic system? Also, hydraulic systems are closed, meaning the oil gets hot. Are water pumps a closed system or open? Just something to think about. Share this post Link to post Share on other sites
mikekot3 93 #3 Posted October 11, 2015 A hydraulic pump delivers a large volume of oil not 2500 psi and low volume. Share this post Link to post Share on other sites
953 nut 63,549 #4 Posted October 11, 2015 If you want to try it I'm willing to watch! I doubt that it will work, but I have been wrong before. 2 Share this post Link to post Share on other sites
DennisThornton 4,772 #5 Posted October 12, 2015 What mikekot3 said!Your on your way to have a high pressure but low volume hydraulic pump. It will very slowly blow all of you hydraulic lines! Share this post Link to post Share on other sites
bmsgaffer 2,065 #6 Posted October 12, 2015 Most pressure washer pumps are 2gpm or less, you can come across them up to 5gpm or so.Another big point is that most pressure washer pumps are designed to have a pressurized input (your garden hose provides 10-30psi usually), they are not designed to suction or scavenge for fluid and thus will cavitate and probably self destruct.Also the pressure orifaces are designed for water, oil will be much thicker and thus will not flow as fast and probably build up so much pressure that your pump will either lock up or break itself...Not saying you shouldnt try it... please video it if you do... just giving some more theory to it. 1 Share this post Link to post Share on other sites
