		H60 12v starter? Part number? Anything please...
					By
DennisThornton,   in Wheel Horse Tractors
Similar Content-
			 By Chuck14025 By Chuck14025
 1994 520 H. Starter just clicks.
 1. Battery 12.6V, load test OK., New solenoid. Ground good. Key switch tested ok. Wiring diagram shows a 'kill' relay - I can't find it on the tractor. Checked the 3 relays under the battery box - they work. Neutral switch, PTP and seat switch work mechanically.
 2. Not able to find article on this problem when searching. There must be dozens. How do I find them?
 3. Can I test the starter without taking it out?
 4. Is there a 'kill' relay?
 thank you...
			 By ToroWheelHorseRookie By ToroWheelHorseRookie
 Please Help-- I inherited this work horse from my father in-law after being passed down from his father. I recently brought my wheel horse in for repairs and the service shop said they were unable to find the part; starter/solenoid. I did not want to give up on this beast as even the repair shop said this is a well made machine and is better than anything built today. I eventually found the part but because the shop left the part uninstalled I was unable to see how the starter was wired. Yesterday, I installed the new starter/solenoid but when I connected the battery terminals the tractor wanted to start on its own. I quickly disconnected the terminals and analyzed the electrical schematic map but I am baffled on the proper wiring. I only have a positive (red) battery terminal wire, another red wire, black (ground) wire, and a blue wire with a slot connection. I included pictures of the starter and the electrical schematic map. Any help would be much appreciated!! I l would like to fix this on my own as this seems to be a simple wiring issue. I can add pictures of the tractor itself, but at the moment its under a tarp in a shed at night. Thank you in advance, Matt
 Electrical Guide.pdf
			 By RJ Hamner By RJ Hamner
 Rebuilding a C160. everything worked prior to rebuild
 Engine was fairly high time so machined .020 over and rebuilt
 Finished rewiring and made sure all the circuits were in order
 Starter would spin the engine. Made new coil wire and installed new spark plug
 Starter won't turn the engine. Tried several times with and without spark plug Same results
 Starter was what I took off the tractor prior to rebuild but can't say it is orininal
 So.......Am I missing something or is a new starter going to be the answer?????
 Thoughts? Ideas?
 All help/input appreciated
 BTW: Don't know if it means anything but the gear does not retract when key is moved back to ON
 Bob
			 By Postal By Postal
 I recently acquired a Kohler K321PT. I want to put it on my Raider 10 but it has a recoil starter. My question is can I put an electric start on this motor and will it bolt up to my Raider 10 to replace the Tecumseh hh100
			 By GoBucks By GoBucks
 Since I bought this in April, I had one time when I went out and it wouldn't start, no turning over, just dead, but the battery etc was good. I looked around for awhile, didn't really do anything, and it just worked. It's been several months, and hasn't done that again until last week. I checked the battery again, looked for any loose wires, etc No luck. The gauges, test lights all come on.
 How do I see if the starter is getting power? I saw the 2 big nuts, one has a wire, the other doesn't. There is also a small white push on type connector wire. Where do I check for 12Volts? Any other thoughts of possible suspect areas to check for a loose wire?
 On a slightly related note, when I bought it, the headlights/taillights worked, by the time I trailered it home 3 hours, they didn't work, but everything else did,
 Thanks,
 Sam
