Timothy 0 #1 Posted October 7, 2015 I just got one of these snow blowers I need to find a good pic of the belt routing and the part numbers for the belts. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,750 #2 Posted October 7, 2015 Welcome to the forum.http://www.wheelhorseforum.com/search/?q=st-267&type=downloads_file&sortby=relevancy&page=1Garry Share this post Link to post Share on other sites
bmsgaffer 2,054 #3 Posted October 8, 2015 I've never even heard of these before but ironically enough I did run across a forum member selling these very belts:http://www.wheelhorseforum.com/topic/59331-wheel-horse-walk-behind-blower-belts/ Share this post Link to post Share on other sites
trainman 0 #4 Posted October 18, 2015 Ok since I wrote this I found the belts Now I need to find a seal if anyone has nos parts it's a oil seal for the snow blower gearbox I have yet to find one. Part number is mw-10459 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,750 #5 Posted October 18, 2015 (edited) You should have no trouble getting a seal from a bearing shop or Napa. Try this linkhttp://www2.chicago-rawhide.com/popup_parts_lookup_457010.htmThe seals are listed by shaft size so a .750" shaft will have a CR/SKF part number in the 75xx range + or -. Using vernier calipers determine the bore diameter the seal goes into and the depth of the seal.Enter shaft size in the 2nd box (ie .750)These are the seals Napa carries.If you have trouble post the dimensions.Garry Edited October 18, 2015 by gwest_ca 1 Share this post Link to post Share on other sites
