snowhound 106 #1 Posted October 2, 2015 Recently picked up an early 70's C-160 that appears to have a warped head. I placed it on piece of glass and was able to slide a .004 gauge under on one side, I didn't try a thicker gauge. Would it be worth trying two head gaskets? Does anyone have a good head to sell?Ed Share this post Link to post Share on other sites
tunahead72 2,581 #2 Posted October 2, 2015 There's an excellent tutorial here on flattening a cylinder head:http://www.wheelhorseforum.com/topic/38803-how-to-renew-cylinder-head-gasket-sealing-surface/This is a little tedious and time-consuming, but should be done for any head that shows a .003" or larger gap. And ultimately, it's very satisfying to see the results of the process.I've never tried two gaskets, but my gut feeling is that it wouldn't work as well as flattening the head and installing one NEW gasket. 2 Share this post Link to post Share on other sites
Ed Kennell 42,992 #3 Posted October 2, 2015 Yeah, follow Eds advice and flatten your head using SOI's tutorial. It is not that difficult and if you buy a used head, it will probably also need to be flattened . I use a large black ink magic marker to coat the head to ID the high spots and I recoat the head after each series of sanding. I feel the ink is thinner and it dries instantlyDo not use two gaskets. 2 Share this post Link to post Share on other sites
infernus 8 #4 Posted October 3, 2015 Never double gasket. You might as well not use a gasket at all then... they'll leak for sure. Take it to a machine shop like Napa or Bumper to Bumper that does machine work like valve grinding and flywheel resurfacing... they can deck it for a couple bucks. I wouldn't worry about it bumping compression up much. 1 Share this post Link to post Share on other sites
snowhound 106 #5 Posted October 5, 2015 Thanks for the replies I'll pick up some glass and give it a try. Share this post Link to post Share on other sites
