Valve stems
I know you can go with stems or tubes. My 62 has original tires on the font and tubes would probably be the better solution however the reason it is flat is do to a split valve stem. Where can you buy these from. It is much shorter then my truck and other vehical stems. Are they all the same or are there different size stems with different size tractor wheels?
Thanks for the help
Ian T
TJ
I would think that any good auto parts store would have a wide selection.
A tire shop should be good place to check too.
rustbucket
I second that any good auto parts place or tire shop should have em in every size if not a decent match.
BPjunk
Ian,
Take a measurment on the lenth of the valve stem and post it or send me a PM ...... because some where in my garage I got a bunch of 'em of the little un's.
Wild Bill in Richmond, Va.
